Thread: newbie needing help
  1. Question newbie needing help
    hi every 1 first post and need help,
    bought a 52 plate bora 1.9 tdi 130 se in april with 64000 miles on it,
    just yesterday the glw plug light started flashing and now the esp light comes on and the rear brake lights dont work has any one got any idea if this is linked some how or am i just unlucky
    cheers for any help in advance
  2. Re: newbie needing help
    Hi i suggest you check the brake light switch
  3. Re: newbie needing help
    will check that out cheers
  4. Re: newbie needing help
    Chester-le-Street, United Kingdom
    Quote Originally Posted by Sother View Post
    check the bulbs first. if both outer bulbs are out the glow plug light will flash even though the centre high level light still works.
    not sure about the esp light unless you have knocked the dash switch by mistake and turned it off?
    or as stated earlier if brake switch on pedal has totally failed it may/or may not cause esp light to come on perhaps?
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  5. Re: newbie needing help
    just a quick thanks to Kenney and Stewy L for the help, it was the brake switch, replaced and all sorted now
    Cheers Lads
  1. Please Help Newbie Needing help
    By Glantor in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-06-2008, 01:35 PM
  2. Please Help newbie needing advice
    By gingerjeff in forum Golf MK3 - 1993 - 1999
    Last Post: 20-05-2008, 06:27 PM
  3. Newbie needing help!
    By dasmith21 in forum New Member Introductions
    Last Post: 18-02-2008, 04:05 PM
  4. Newbie needing help
    By huzi7 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-08-2007, 12:09 PM
  5. Newbie,needing advice
    By Driver1.8 in forum New Member Introductions
    Last Post: 04-05-2007, 12:35 AM
