Thread: help with clutch
  1. help with clutch
    Jun 2008
    hi i own a 2.0tdi sline avant 57 plate.its just been in for a modified clutch plate to stop judder from cold ,which it hasn't.has anyone else had this trouble after mod clutch .many thanks
  2. Re: help with clutch
    May 2007
    knee deep in clunge
    14 Post(s)
    The thinner clutch centre plate has fixed 100% of the complaints i have dealt with.
    However the old clutch cover requires resetting for the new plate and if this isnt carried out the judder will continue unless you have a different cause.
  3. Re: help with clutch
    Jun 2008
    many thanks a8 tech ill have to visit the garage again then to see whats up. i must say im concerned with the idea of a thinner clutch .is that just thinner due to construction or friction material ,eg is it going to last as long . many thanks
  4. Re: help with clutch
    May 2007
    knee deep in clunge
    14 Post(s)
    There is no issue with the service life of the modified centre plate
  5. Re: help with clutch
    Jun 2008
    hi all
    just a quick line to say car has now had clutch pack and dual mass flywheel ,seems to finally done the trick .
  1. clutch
    By subly in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-10-2008, 01:07 PM
  2. Fan clutch - A6 - AKE
    By davej in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-05-2008, 10:33 PM
  3. G60 VR6 Clutch in TDi
    By t0m541 in forum Audi A3 - Archive Topics
    Last Post: 28-03-2008, 05:20 PM
  4. t4 Clutch
    By ralph22 in forum The Commercial Range
    Last Post: 14-12-2007, 02:32 PM
  5. New clutch judders - faulty clutch fitting or fly wheel?
    By srana in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2007, 09:31 AM
