Thread: 3rd Gear Crunch
  1. 3rd Gear Crunch
    Mar 2006
    Hello
    I have a 51 plate passat tdi sport with 6 speed manual and just recently I have noticed that very rarely it crunches ever so slightly when gearing down from 4th to 3rd.
    Only happend in third gear and only a slight cruch.
    When going up the gears no problems, just when i come from 4th to third but even this is very rare.
    Can someone shed some light on what to do or what it might be?
  2. Re: 3rd Gear Crunch
    Mar 2006
    Also
    could someone maybe tell me how to change the gearbox fluid as I've read it could be that?
    Just need to know:
    How to drain the fluid, insert new fluid and what fluid to use for my gearbox?
  3. Re: 3rd Gear Crunch
    Mar 2006
    hello
    as an update, been driving the car now again and it hasnt done it all.
    Still would like to know what i should do?
    Oh yes car has 113k, full vwsh apart from last service which went to independant vw specialist garage
  4. Re: 3rd Gear Crunch
    Mar 2007
    How do you hold the gear knob when you change? I find it is easy to press down on the gear knob when changing into third (pressing down like you have to when changing into reverse). I find the change into third is a bit more difficult when I do this.
  5. Re: 3rd Gear Crunch
    Mar 2006
    Quote Originally Posted by Zub View Post
    Hello Zub
    I'm not sure what the benefits are of doing this, can you explain?
    I'm assuming you have a crunch too in third?
    Also i've noticed if your harsh with the change, meaning if you chnage quite fast then it crunches once maybe in the whole drive but if your nice and easy its fine and no crunch.
    I was thinking if I change the fluid that might help it.
  6. Re: 3rd Gear Crunch
    Mar 2007
    I'm not saying it is a benefit, what I am saying is that I find it is easy (easy in a bad way!) to put more downwards pressure on the gear knob when changing into third than with 1st or 5th. Maybe the downwards pressure when changing into third makes it a bit harder to go into gear.
    I wouldn't say mine crunched at all, it just seems a little harder to put into third if I put downward pressure on the gear stick. If I pay attention and shift into third with no downwards pressure it changes the same as any other gear.
  7. Re: 3rd Gear Crunch
    Mar 2006
    I see what your saying Zub
    Thanks for the Info
    I'll just keep an eye on this as its very very rare it happens.
    I was wondering if you or anyone else knew how to change the fluid on the gearbox or even check the level?
  1. Second gear crunch 1.9 TDi S
    By superstevie in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-01-2009, 09:50 PM
  2. Please Help 1st - 2nd gear crunch!
    By theguvnor21 in forum Ibiza - Cordoba
    Last Post: 28-06-2008, 05:23 PM
  3. Question Rattle Clunk sound from gear box when changing gear?
    By jasonocallaghan in forum Golf MK5 - 2004 - 2009
    Last Post: 27-06-2008, 12:20 AM
  4. 5th gear crunch leon 110 tdi
    By seatcol in forum Leon
    Last Post: 21-03-2008, 02:35 PM
  5. 2nd gear crunch noise
    By DAVIDBLUEJEAN in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-02-2008, 11:35 PM
