Thread: beeping
  1. beeping
    Jul 2008
    when i lock my a4 with key thob after half hour to a hour bleeping noises start coming from the boot is this the alarm going off coz the indicators dont flash if i unlock it to stop it will lock its self and do it again any help will be grateful
  2. Re: beeping
    Dec 2008
    I have the same problem with my A4 at the moment, when I arm the alarm my indicators don't flash as they used too, and after around 30 mins the bleeping starts I disarm and they stop but start again not long later,,,,,
    any help wouyld be great
    thanks in advance jarvis
  3. Re: beeping
    Jul 2008
    Wales
  4. Re: beeping
    Dec 2008
    Midlands
    May this be a fuse problem?
  5. Re: beeping
    Sep 2007
    Windsor
    I don't think it would be a fuse problem. More likely to be as audia4lyn suggested - the battery in the siren unit. I have also had problems with my alarm when I turned on the 'confirm anti-theft beep' function using VagCom. Whenever I locked the car, the alarm would beep once (as intended) then more often than not would continue to beep. I have from time to time heard the alarm at random intervals but cannot be 100% sure it was my car as the indicators were not flashing. I have since disabled the 'confirm anti-theft beep' and not had any problems. I haven't got round to doing any more investigations yet.
  6. Re: beeping
    Sep 2008
    Birmingham
    I'm pretty sure this is the failing internal battery, this problem was coming up a lot on here not that long ago. If you have a search I think there's guide to replacing the supposedly non-replaceable battery unit to save yourself some money.
  1. beeping from trunk
    By Smart Alec in forum Golf MK4 - 1999 - 2004
    Last Post: 07-01-2008, 10:20 PM
  2. Beeping TT
    By Bluoranges in forum TT - 8N Forum - 1998 - 2006
    Last Post: 23-08-2007, 09:04 PM
  3. Beeping noise from boot!!
    By sted in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-06-2007, 07:16 PM
  4. beeping noise
    By kcan in forum Audi A4 - Archive Topics
    Last Post: 02-05-2007, 09:10 PM
  5. Passat beeping noise!
    By davewuyts in forum Passat - Archive Topics
    Last Post: 30-03-2007, 11:09 PM
