Thread: radio fuse location GT TDi 140
  1. radio fuse location GT TDi 140
    birmingham
    hi all
    have a bit of a problem with my 2004 gt tdi
    i tried installing a bluetooth hands free in my car and blew the radio or at least i think i did i got a new radio from my mates car and that too does not work?
    so i would say its a fuse but i cannot find the fuse for the radio. i have checked the fuse behind the radio and swapped it( even though it was ok)
    so now i'm loking for the fuse in the car
    any help would be most greatful
    nav
    Golf Mark 5 GT TDI 140
  2. Re: radio fuse location GT TDi 140
    Angus, Scotland
    Hey Nav,
    The fuse box is on the right hand side of the dash. You need to open the door to get at the end panel, then remove it with your key. There is a slot near the bottom specifically for this.
    There should be a fuse in there for the radio.
    Hope that helps
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  3. Re: radio fuse location GT TDi 140
    birmingham
    thanks for reply but it not in that fuse box, i've tested every one in that box.
    i believe there is another one but not sure where in the car that is.
    nav
  4. Re: radio fuse location GT TDi 140
    Angus, Scotland
    Hey Nav,
    The only other location for fuses is in the engine bay.
    I believe there is a fuse box in the plastic compartment next to the battery, could check there!! If I get a chance at lunchtime I'll have a look and see if I can find out exactly where it is fused
    Paul
  5. Re: radio fuse location GT TDi 140
    Dec 2007
    Darlington
    I think the fuse for the radio is located in the plastic box next battery in the engine compartment.
    Hope this helps.
  6. Re: radio fuse location GT TDi 140
    birmingham
    hi
    yes it was in the fuse box in the engine comp
    changes the fuse and all is working
    thanks guys
  1. help, Location of internal fuse box
    By Don_passat98 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2008, 09:26 AM
  2. cd changer fuse location
    By hackman in forum Golf MK4 - 1999 - 2004
    Last Post: 05-01-2008, 06:54 PM
  3. fuse location for radiator fan on mk4 golf
    By elliotta44 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-06-2007, 07:36 AM
  4. fuse location for petrol locking cap golf mk4
    By stejuk in forum Golf MK4 - 1999 - 2004
    Last Post: 31-05-2007, 07:09 PM
  5. Radiator fan fuse location
    By Dacabbie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2007, 01:47 PM
