Thread: Error Code 17965
Results 1 to 10 of 18
  1. Error Code 17965
    Hi All
    Just signed up - i have a 1.8T ibiza and was wondering if anyone here can shed any more light
    Got VAG COM and scanned car and was getting 17965 posistive deviation - main vac hoses have been replaced, new maf and n75 valve been changed -
    i initially had the problem but when i changed the hosing it worked - but then a day later, its doing the same and not boosting properly -
    ive checked intercooler pipes and they are on firmly -
    anyone know another point of call to check?
    THANKS
    Oct 2005
    Lutterworth
    If you have a registered VAGCOM log the engine measurement blocks that show airflow and boost during an acceleration run to see what is happening when the code is logged.
    If you are near LE17 I can help out, or post the log here.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Tuesday16January200722:41:506K0 906 032 1.8L R4/20VT SEA 0002Group A:'002Group B:'115Group C:'118RPMLoadInj. On TimeMass FlowRPMLoadAbsolute Pres.Absolute Pres.RPMTemperatureLoadAbsolute Pres.TIMETIMETIMEMARKERSTAMP /min% ms g/sSTAMP /min% mbar mbarSTAMP /min°C% mbar0.912240124.815.1752.440.012000114.3219013200.4120803125.114502.212560128.615.5864.311.422360126.3211014701.8224402930.214903.412880130.815.5872.752.612680129.3202015103.0127602930.215004.613200133.115.9983.063.82960131.6195014804.230802928.214805.83480134.616.8191.1753280133.8191014705.434003028.2147073800131.616.495.676.23600133.1186014706.636803028.214708.24080132.316.81101.317.43880131.6186014607.839603228.214509.44360130.116.81108.788.64160130.818401430942803323.9141010.64600130.117.22114.039.84440130.11810139010.245203319.2138012.014880129.317.22121.7511.114720129.31790136011.6148003414.1136013.45160125.617.22121.8612.414960127.81780134012.9150403610.2134014.625360124.117.63127.2213.825200124.81780134014.2252803610.21340
    Logs Above - My actual boost is no where near hitting requested boost - My N75 duty is very low - but as said, this was replaced -
    Ive done all the checking i can for an air leak - Im hoping ive missed somewhere as otherwise, I could be looking at a sticky wastegate - which means cleaning or replacing turbo -
    Seeing a VAG technician in about 2 weeks - hopefully will find problem and cost will be minimal -
    Error code im getting is 17965 Charge pressure control - posisitive Deviation
    cheers
    sorry - ive tried posting the logs up by made a mess of it - which button on the toll bar do i use? ive tried the wrap quote/code/php button but didnt work
    thanks
    hi ppl i got the same problem with my vw bora 100pd, got the same error code as above, its not driving aswell as it sud as i hav had it remapped and was flying before, did anybody find out excatly wot it was, it only happened when i got the tappetts replace and the map sensor replaced most help would be appreciated as it is going into the autotrader, dont want the car coming back to me, thanks
    Quote Originally Posted by martyb123 View Post
    apologies for not updating earlier -
    one of the first basic tests i should have done was to disconnect maf sensor but didnt do this as the maf was only about 5 months old -
    the maf was reading to high and therefore indicate a boost leak as this reading would never be achieved -
    thanks
  7. Re: Error Code 17965
    Jul 2011
    guernsey channel islands
    iv had same problem and when disconnect MAF it runs alot better so did u just buy a new MAF?
  8. Re: Error Code 17965
    131 Post(s)
    1973 Post(s)
    Now you have an AMM/MAF fault code.
  9. Re: Error Code 17965
    Jul 2011
    where is the AMM positioned on the ibiza cupras 2002 model?
  10. Re: Error Code 17965
    131 Post(s)
    1973 Post(s)
    On the air box.
  1. engine trouble code 17965 - turbo dying? HELP!!
    By Eshrules in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-08-2007, 10:05 PM
  2. Error code P1553
    By Fozmondo in forum Polo - Derby - Lupo - Fox
    Last Post: 15-05-2007, 08:25 PM
  3. Can someone give me more info on this error code?
    By bamjimpat in forum VCDS - General Questions
    Last Post: 12-05-2007, 01:33 PM
  4. VAG COM Error Code
    By rachykate in forum VCDS - General Questions
    Last Post: 04-04-2007, 10:19 AM
  5. OBD - Error Code Anyone know what this is
    By triman in forum Audi A4 - Archive Topics
    Last Post: 03-02-2007, 06:10 PM
