Thread: Abs Fault
  1. Abs Fault
    Jun 2008
    I have an intermitant fault with the ABS on my 2002 T4 Caravelle. The ABS is activating under light braking 'very intermitantly'. Is this an ABS sensor ?
  2. Re: Abs Fault
    hello mate it could be a broken speed ring, they are hidden in behind the brake discs, on the front they are part of the outer cv joints and on the rear part of the hub or somthing.
    anyway to check them you have to be in behind the wheel with it jacked up and turn it round to look for a crack the speed ring it's self is sort of castalated (like the battlements on the top of a castle) ¬_¬_¬_¬_¬_¬_¬_¬
    if it is cracked the senser cant read it properly and gets confused when mine went it was most noticeable on light braking. the other thing is to get your fault codes read (look at vag com section) bear in mind a bust speed ring prob. wont show a fault (cos the sensor IS working)
    hope this helps nic
  3. Re: Abs Fault
    Quote Originally Posted by nicmas2000 View Post
    hope this helps nic
    I have a intermitent abs type judder when I brake. Do you think this maybe the problem? 2007 T5
  4. Re: Abs Fault
    My lt has had a problem with the abs. The abs is activ under most braking and even when not braking. although after a while the warning light comes on and the ab is disabled. Turns out to be a sensor and a ring. VW aren't sure if the ring is available seperatly...... does anyone know if it is? pass rear.
    thanks
  5. Re: Abs Fault
    anyone?
  1. ABS fault from vag-com
    By tony_anon in forum VCDS - General Questions
    Last Post: 07-10-2008, 10:43 AM
  2. Bodywork fault or design fault ?
    By mandh22222 in forum Eos
    Last Post: 03-05-2008, 07:21 AM
  3. ABS fault from vag-com
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-02-2008, 06:39 PM
  4. Air con fault - help!!
    By LeeinBunwell in forum New Member Introductions
    Last Post: 13-10-2007, 07:59 PM
  5. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
