Thread: Octavia 1.9tdi water coolant temperature sensor
  1. Wink Octavia 1.9tdi water coolant temperature sensor
    Beato19 Guest
    Hi all, wonder if anyone can tell me where the above sensor is on the engine as I can't see it in the obvious places adjacent to the radiator etc. Could it be behind the drive belts somewhere?
    Also like to mention that the sensor was priced by a local Skoda dealer at £23.00p + vat. I managed to get one from my local motor factor shop for £13.00p including vat. I cheekily asked the Spare parts man at the Skoda dealers if the sensor was the right one and he confirmed that it was. I suppose it pays to shop about a bit me thinks. Cheers all. Neil.
  2. Re: Octavia 1.9tdi water coolant temperature sensor
    vagtune Guest
    HI Neil,
    The sensor will be on the back of the engine where the gearbox bolts on, it will be a green 4 pin sensor. You will have to lift the cover off the top pf the engine, it just pulls off. The sensor is only clipped in with a plastic u clip
    Hope this helps
    Lee
    VAGTUNE
  1. A6 1.9 TDi coolant temperature sensor
    By PFPH in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-04-2008, 11:34 PM
  2. A4 Tdi B6 Engine Coolant Temperature sensor replacement
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2008, 10:58 PM
  3. **Coolant Temperature Sensor**
    By Joshuaantonio in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-01-2008, 10:57 PM
  4. Coolant temperature sensor reading too high
    By vlad21 in forum Golf MK4 - 1999 - 2004
    Last Post: 23-11-2007, 01:32 PM
  5. Coolant Temperature Sensor
    By shahabudeen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2007, 09:25 AM
