Thread: Can anybody help with a judder??
  1. Can anybody help with a judder??
    When I pull up in my car I've started to feel a judder coming through the break and clutch pedals, I'm sure it's not the breaks and it only happens intermittently. Could it be the clutch going??
  2. Re: Can anybody help with a judder??
    Nottingham
    They are two seperate pedals. I think you have to carefully examine what is juddering and what isn't. It's pretty hard to think that you have a brake and clutch fault....
    When were the front disks last changed and what do they look like?
    Greg.
    Quote Originally Posted by pg20 View Post
  3. Re: Can anybody help with a judder??
    Aug 2008
    Do you get the judder if you pull up with the engine off and coasting in neutral ?
    Does it judder if you pull up with the clutch depressed or does it judder if you drive with low rev sand clutch still engaged. If the latter it might be the DMF failing to damp vibrations at low engine revs before you disengage the clutch.
    Jules
  1. Ive Fixed My A4 Tdi Judder At Last Please Read If You Have A Judder
    By justin@justinwa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-11-2009, 08:32 PM
  2. car judder
    By husky jim in forum Golf MK3 - 1993 - 1999
    Last Post: 25-08-2009, 08:57 AM
  3. Judder
    By Ednewns in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-07-2008, 11:13 PM
  4. A4 Judder
    By otis_b in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-02-2008, 06:05 PM
  5. 2.0 TDI DSG Judder
    By akafudge in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-11-2007, 04:22 PM
