Thread: annoying rattle
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: annoying rattle
    Mar 2007
    Sunderland
    thanks again people,that definately sounds like the way to go,will have it sorted as soon as i can sort out a day of work,will let you know the outcome....thanks again
  2. Re: annoying rattle
    Jul 2006
    outer space
    Hi - I have the same problem on mine, does anyone know how hard they are to change?
  3. Re: annoying rattle
    Quote Originally Posted by rhencullen1989 View Post
    AAh, a friend of mine had a nasty rattle/droning/hum from his passat diesel 2002 plate, that turned out to be the auxillary drive belt tensioner and pulley, apparently the pulley has a one way clutch or damper assy which can fail, he also said that the belt tensioner (auxillary) was oil damped as well as spring loaded and the oil had seeped out. Best to get sorted as can lead to other problems.
    I've got exactly the same problem, and the mechanic told me its the belts as well, ave had the problem for a month now, really should get it replaced and the timing belt and the water pump.... what can i say times are hard, cant afford to do all that at once.
    can i just ask, does this forum recognise html?? if i need to ad a link, do i do it in html format or what.
    Audi a4 1.9tdi 6 Speed Sport 53 reg
  4. Re: annoying rattle
    Aug 2008
    I have the same problem,power steering tensioner gives annoying rattle at low rev and on full lock.
    I would be interested in fixing problem myself,would anyone have done this repair before?
  5. Re: annoying rattle
    Sep 2007
    Glasgow
    Haynes manual tells you how to do it but it seems to involve stuff like removing bumper, removing lock carrier etc. Seems straightforward enough if you have the skills.
    That said, I asked a local garage if they would do it for me and they balked at the thought of bumper and lock carrier removal.
    Took it to a specialist independent instead, cost a bit over £100.
    Peace of mind for a non-technical owner.
  6. Re: annoying rattle
    Well mine has just been done.
    I have an 02 Reg tdi, the tensioner part was now a mod and cost £90
    The labour was 2 hrs;
    - result the car feels like its back connected to the road.
    The mechanic mentioned that these aux belts can fail and cause more serious damage.
    Re the O/T no rattle!
  7. Re: annoying rattle
    #17
    Aug 2008
    anyone have a soft copy of Haynes manual,or know where i get one for 02 model,i have the manual for the 1995-2000 model.
    i am still interested in doing repair myslef.
    im not afraid of taking the bumper off.just cautious of the power steering belt and removing the tensioner.
    Will i have to touch the timing belt to remove the tensioner.if so i'll leave to the professionals to fix.
  8. Re: annoying rattle
    #18
    Jul 2006
    outer space
    Interesting......i will give it a bash myself - does anyone have the part number i need?
  9. Re: annoying rattle
    #19
    Jul 2006
    outer space
    FYI - Car had to go in to garage ASAP yesteday, turns out it isnt the P/S belt tensionor, but the clutch assembly on the alternator!
  10. Re: annoying rattle
    #20
    Jul 2008
    Hi I have a passat tdi highline, 04 plate. When the engine is revved there is a rattling sound comes from underneath the bonet as if some part of the car is catching some moving parts in the engine. The sound goes higher when gear change is imminent, but as soon as the car goes on higher gear the sound goes down and up again before the next gear shift. Any idea people ? Much appreciated. Thanks.
  1. Vista is annoying... need XP
    By Loofer in forum Home Tech Shed
    Last Post: 08-06-2009, 05:05 PM
  2. Annoying...!!!
    By sonbow1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-03-2008, 09:51 AM
  3. annoying missfire!
    By akaax in forum Polo - Derby - Lupo - Fox
    Last Post: 22-01-2008, 08:18 PM
  4. Alarm is annoying me.
    By daniel graham in forum Audi A3 - Archive Topics
    Last Post: 03-07-2007, 09:56 AM
  5. My A3... It's annoying me...
    By firestar2k3 in forum Audi A3 - Archive Topics
    Last Post: 16-01-2007, 01:00 AM
