Thread: VR5 Questions...
  1. VR5 Questions...
    Hey guys,
    I have a few questions for you regarding the passat VR5 all wheel drive models, with a manual transmission.
    Do any of you have pictures of the flywheel, clutch, starter, flywheel spacer (or hub)?
    Also, is it possible for any of you to source these parts?
    I am looking to get all of the above shipped to the United States, as I am currently in the process of swapping a VR6 Turbo from my Corrado into a 1988 Audi 80 Quattro.
    There are people here who make parts that will work, however they are VERY expensive, and are of a motorsport caliber, and I am not in need of anything along those lines.
    I am just looking for OEM pieces.
    Again, I need the flywheel, and flywheel bolts, flywheel spacer (or hub, depending on what you call it), and starter.
    Thanks a million.
    ~ John.
    Please contact me via my E-mail account.
    Turboegt@gmail.com
  2. Re: VR5 Questions...
    134 Post(s)
    2005 Post(s)
    That car was never sold in the UK, we only had the 2.8 V6 (the Audi wide angle) engine and later the 4 cylinder TDI. All the parts for the Syncro and 4 Motion VR5 with the AGZ and the later 2000 onwards AZX engine (they used the 01A transmission as does the 88 80q) are easily available from a VW dealer although they may take time to arrive when the car wasn’t available in your market. Even here you would be looking at two weeks. As for part numbers a few examples are the engine to box intermediate plate, VW part number 022 103 551 which costs £80 and the flywheel is 071 105 266 but it costs a terrifying £535 because it is a dual mass unit. However it is available from a company called LUK. It was only ever used on the Passat with the VR5 engine and four wheel drive. The clutch was used in a variety of longitudinal installation VAG vehicles from 1990 to 2005 and is available from LUK under their part number 624 3032 00 and also from Sachs under the number 3000 387 101. The flywheel bolts are off the shelf VAG parts, number N 906 978 01 and so should easily be available from your local VAG dealer and the manual gearbox version didn’t use the crank to flywheel 15-mm spacer and adjustment shim, only on the auto model flex plate.
  3. Re: VR5 Questions...
    First and foremost, I just wanted to say THANK YOU SO MUCH!!!
    I have been searching for this information for SOOOOOO long.
    ok...
    I already have the intermediate plate.
    So I just need the flywheel, flywheel bolts, and a clutch.
    Then I just have to do the rest of the fabrication, but that's the easy part!
    I know you've gone through a ton of work for me already, however I have a one more question for you.
    Is the starter unique to the VR5 Passat?
    I know very little about Audi part interchangability, however if you ever have any VR6 questions, I would be more than happy to answer them for you in return!
    I AM GETTING SO EXCITED RIGHT NOW!
  4. Re: VR5 Questions...
    134 Post(s)
    2005 Post(s)
    Calm down old boy, you will do yourself a mischief! The starter is unique to the VR5 engine only but not just the four wheel drive version. The VW part number is 012 911 023 but has changed to 012 911 023 X for an exchange unit and over here it costs £120 plus an exchange surcharge as you have no old unit to hand back. The Bosch part number is 0 001 107 070 for a new unit or 0 986 020 850 for a remanufactured unit. I have sent you a PM so you can send me your email address; I have some pictures and diagrams of the starter.
  1. New, so a few questions.
    By Rob.H in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-05-2008, 12:18 PM
  2. 2 Questions
    By Jimp45 in forum Golf MK5 - 2004 - 2009
    Last Post: 20-03-2008, 11:55 PM
  3. A few questions...I'm new to these.
    By FLHRCI in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-01-2008, 12:02 PM
  4. V5 questions..
    By Plug in forum Golf MK4 - 1999 - 2004
    Last Post: 25-11-2007, 09:04 PM
  5. Few questions......
    By Sisson in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-09-2007, 12:46 PM
