Thread: A3 1.6 overheating ?
  1. A3 1.6 overheating ?
    Hello everyone this is my first post so bear with me please.
    I have a 2001 A3 1.6 Se that has started to over heat and lose water.There doesnt seem to be any leaks any where
    As I am not that mechanicaly minded I have just drained it and topped up with anti freeze .This still hasnt stopped the overheating.It stays around 108-115.Any ideas?
    TIA
    Adam
    Hi Adam Get the coolant checked for hydrocarbons. I'm sorry but it could be the head gasket.
    Good luck Boardboy
    Dec 2006
    if you check the oil via the OIL cap,, is there like a white cream build up all around the inner old cap..
    if so... head gasket....
    RicKT
    The head gasket dosent always force water into the oil, ie. when the gasket has gone between the cylinder and the water jacket. Then you will get pressurisation of the system from the cylinder responsible and more than likely a fair bit of steam out of the exhaust.
    There is a brilliant additive, I think made by Holts which not only cures these leaks from the head gasket, it also cures leaks from the oilways into the water aswell. You just add it to the water in the radiator and away you go, they say fixed in minutes. I used some on a leaky MG Midget a couple of years ago and it hasn't leaked or overheated since. It isn't particularly cheap at around £12.00 but its worth a try before going for the gasket at several hunderds.
  1. A6 1.8T SE Overheating?
    By Cambrai in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-05-2007, 04:48 PM
  2. A6 Still Overheating
    By ostinpawas in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-05-2007, 04:42 PM
  3. A6 Overheating
    By ostinpawas in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-04-2007, 01:27 AM
  4. Mk 4 gt tdi OVERHEATING!!!!!!!!
    By jamjam1979 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-01-2007, 02:06 PM
  5. Overheating? - Maybe
    By chris green in forum 80 - 90
    Last Post: 03-07-2006, 04:20 PM
