Thread: 1997 Passat 1.8 non turbo rough idle fault
  1. 1997 Passat 1.8 non turbo rough idle fault
    I have a passat as described above, with a very unusual fault. It idles very badly/ stalls, cuts out when cold. After running for a few minutes, it settles down and is much better. Also it failed MOT for emissions test.
    There are no fault codes on vag-com.
    It has a new air flow sensor
    Vacume lines have been checked and split crank case breather replaced.
    Throttle body has been cleaned and adaption done.
    New air filter, plugs and plug leads.
    I am out of ideas now. Can anyone on here help please?
    Oct 2005
    Lutterworth
    Change the coolant temperature sensor.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    The car certainly has symptoms of a faulty temperature sensor, but I thought that would give a fault code on Vag-com if it had failed, or is that not correct?
    Oct 2005
    Lutterworth
    only if it is totally stuffed.
    You can read the output with vagcom to test.
    Passat 1.8SE 1998
    Thanks for the succestion. I found the temp sensor to be reading incorrectly because someone had replaced it with the wrong sensor in the past. Correct sensor fitted and it is running much better.
    However I also took it for MOT and it failed for carbon monoxide. 0.8 where limit is 0.5.
    Any suggestions?
    Oct 2005
    Lutterworth
    Give it a really good blast up the road on the way to the retest and see if it is better.
    Passat 1.8SE 1998
    I think it needs a bit more than that. It has a slight misfire when cold and the exhaust gas smells a bit even when warm- like an older less efficient car does.
    The car is also fitted with LPG which I have now got working again and when on LPG, it has a destinctive misfire.
    LPG always shows up faults more obviously than petrol. The slight misfire when cold turns into an obvious one all the time, so i think that is what I have to fix. It also rules out a petrol fuel system fault.
    Any suggestions greatfully apreciated.
    Doing a favour for a friend has turned into a nightmare, with one fault after another on this car
  1. 1.8t a3 running rough poor idle no power???
    By djglovehead in forum Audi A3 - Archive Topics
    Last Post: 10-04-2007, 06:33 PM
  2. 97 1.8 Non Turbo Rough Idle / Hesitation
    By RobNorwich in forum Passat - Archive Topics
    Last Post: 29-03-2007, 07:03 PM
  3. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
  4. Rough on idle/drive 1.9TFI 150,
    By RickT in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-01-2007, 11:36 AM
  5. TDI Turbo Fault??
    By Chilly in forum Passat - Archive Topics
    Last Post: 17-03-2006, 08:58 PM
