Thread: How do you know your ABS is faulty?
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. How do you know your ABS is faulty?
    Mauritius
    How would you know that your ABS is not working properly? Would this have any impact on the braking system?
    thanks
    A4 1.9TDI 130Bhp 2001
  2. Re: How do you know your ABS is faulty?
    134 Post(s)
    2022 Post(s)
    Does the ABS light come on at start and then go out?
  3. Re: How do you know your ABS is faulty?
    Chester-le-Street, United Kingdom
    Quote Originally Posted by tyberwan View Post
    thanks
    crasher,
    judging by your very speedy reply to his call for help, and his lack of response to your question,we can only assume that the lucky guy was on
    a promise
    give her one for both of us son
    first time i was up a ladder i was down a well
    4th cog,--two to go
  4. Re: How do you know your ABS is faulty?
    Dec 2006
    If there is any fault at all, the ABS light will be tiggered and it will stay on all the time..
    Once this light stays on the ABS will be de-activated to ensure the braking system will work with out fault.
    Rick
  5. Re: How do you know your ABS is faulty?
    Quote Originally Posted by RickT View Post
    Rick
    thier is only one tigger and vw don't have him
    take care
    stewy.
    4th cog,--two to go
  6. Re: How do you know your ABS is faulty?
    134 Post(s)
    2022 Post(s)
    Stewy, you been at the pop again?
  7. Re: How do you know your ABS is faulty?
    Mauritius
    Sorry guys
    Was busy trying the car on the highway. The light comes on and goes off as usual.
    The reason I asked is I have noticed that when I apply my brakes and release it 4-5 times successively, it then becomes difficult to brake. The car will take more time to slow down as if the brake pad is just skidding over the brake disc. I am sure this is not normal but applying brakes 4-5 times successively is also not a common occurence.
  8. Re: How do you know your ABS is faulty?
    134 Post(s)
    2022 Post(s)
    That indicates a problem with the brake servo. By repeatedly pressing the pedal you will deplete the vacuum in the servo but it should easily deal with this. Two common problems are water damage to the servo from the plenum chamber filling up with water due to blocked drains and the other is a simple vacuum leak in the system or a vacuum pump fault. A vacuum problem will often also cause turbo boost delivery issues as the turbo vane actuator system is controlled by the same vacuum as is used for the servo.
  9. Re: How do you know your ABS is faulty?
    Apr 2007
    Hampshire
    Possibly also brake fade? Given the location of the OP in Mauritius there's an increased risk of overheating surely? If no joy with the servo might be an idea to try some uprated brake discs capable of handling higher temperatures.
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
  10. Re: How do you know your ABS is faulty?
    yesh
    j c grenache shiraz
    does it show?
    4th cog,--two to go
  1. faulty s3
    By lcbandit in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-05-2008, 10:46 PM
  2. Faulty G81
    By irekstaron in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-02-2008, 07:29 PM
  3. Faulty Turbo ???????
    By atell40 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2008, 10:15 PM
  4. Faulty Brakes
    By gingimark in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-01-2008, 11:31 AM
  5. ?faulty maf
    By pinback2001 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-05-2007, 08:08 PM
