Thread: automatic gearbox problem
Results 1 to 8 of 8
  1. automatic gearbox problem
    Jun 2008
    hi all i hope you guys can shed some light on my problem ive got a 1998 a6 2.5 tdi v6 quattro its done 240000 the problem ive come across when in drive the car just seems to rev out and dosnt pull very well at all and when i use the kickdown it does nothing exept rev it toosh off but if you apply the throttle slowly it sometimes selects gears fine but at a stupidly slow pace ive been told off a few people 3 differant things that could be wrong with it the first being i was told to change the oil whitch i have done to no affect the other was i was told thay have there own ecu for the gearbox if so where is this located and does anyone know where i can get this checked im in doncaster incase theres anywhere near by and the other was that the gearbox is shot i hope its not the gearbox cos these units arnt cheap so please if anyone knows anything about this problem please share your info with me thanks mick
  2. Re: automatic gearbox problem
    Feb 2007
    Tiptronic or Multitronic?
    I would try looking in the VAG COM User locations forum for somebody close to you who could scan your car for faults.
    djl
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  3. Re: automatic gearbox problem
    Jun 2008
    thanks mate i think thats the next road im going down but the only thing thats bugging me is that when i changed the oil it seemed to get a bit better so if it was owt to do with the manegment system it would still be the same
  4. Re: automatic gearbox problem
    Jun 2008
    Lytham St Annes
    Mick, I only just bought my A6, but when I was sat reading through its history I stumbled across a warranty repair form. On the form it said the problem was difficulty in selecting Reverse. The repair section said the gearbox was drained and a new ECU fitted, which implies they have to get into the gearbox to access the ECU.
    Apologies if this response is of no assistance, but I figured it was worth mentioning.
    Good luck mate.
    Gaz
  5. Re: automatic gearbox problem
    May 2007
    Provided oil was correct stuff, and not dextron IV then it sounds like either a ball sticking in the valve pack, or a leaking piston in the box.
    What you are describing is the box flareing, i.e. reving, but not locking into a gear.
    You need to talk to a decent autogear box speacialist. You unit is a tiptronic, so it can be repaired, unlike the more modern CVT, which are best replaced.
  6. Re: automatic gearbox problem
    Jun 2008
    ok thanks for that mate i dont suppose you know anyone thats up to the job or what about you because you seem to know what your talking about
  7. Re: automatic gearbox problem
    May 2007
    best thing to do it put a question on the forum for a good Auto shop close to whereever you live.
    Auto's are a bit of a black art, so you will only find a few shops that deal with them, compared to normal gearboxes.
    I've done my own, but depending on the level of the problem can be quite tricky. If it's just a ball sticking that can be not too expensive, while a piston is a full rebuild.
    Always ring up the guys at www.jpat.co.uk, as they deal with just about all the auto shops, so they should be able to tell you one in your area
  8. Re: automatic gearbox problem
    Devon
    If you live in Devon, I can tell you who not to use, but will not do it publicly. I had some good advice from these guys.
    www.fedauto.co.uk Federation of Automatic Transmissions Engineers
    Good website including federation members around the UK.
    Toby
  1. Audi A4 Automatic Gearbox Problem Leak Jerk Or Rev Etc
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-12-2013, 11:30 AM
  2. automatic gearbox oil top up ????
    By deano1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-11-2009, 03:29 AM
  3. Automatic gearbox problems
    By yellowbeard in forum Golf MK3 - 1993 - 1999
    Last Post: 18-04-2008, 06:57 PM
  4. automatic gearbox
    By armagan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-03-2008, 04:47 PM
  5. automatic gearbox problem
    By max942x in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-12-2007, 08:03 AM
