Thread: led tail lights
  1. Question led tail lights
    Mar 2008
    angus, scotlandshire
    hi guys,
    i'm getting a bit fed up with changing the bulbs in the rear light cluster on my avant and just wondered if any of you have tried led type replacements,more specifically the stop/tail combined type.can you use them without any fault lights appearing on the dashboard?any info on the best type/make to use would be appreciated as i'm LED! to believe that they will last for ages.
    cheers, kip
  2. Re: led tail lights
    Southern County Softy
    20 Post(s)
    LED's will make the blown bulb warning come on unless you fit a resistor.
    A4 2.5 tdi QS (mapped)
  3. Re: led tail lights
    Dec 2007
    theres a few on fleabay with resistor fitted they work prett well just look crap iv had 2 sets and they dont fit right and look crap id rather change the bulbs when they blow but dont forget all the bulbs aint LED only break an main bk lights so u still have to change bulbs
  4. Re: led tail lights
    Mar 2008
    Quote Originally Posted by bez101 View Post
    thanks bez,
    when you say they look crap do you mean they aint as bright as standard bulbs?i realise i would still have to change the other bulbs in the future but it seems to be the stop/tail lamps that my car chews up but from looking elsewhere on this forum audi's are pretty hard on the bulbs any way but i guess it's worth it,best motors ever IMHO......
    cheers, kip
  5. Re: led tail lights
    Dec 2007
    there bright enough what i ment by lookin crap if that they never fit good and they just look well crap now if audi made them then yes they would look like they should
  6. Re: led tail lights
    Mar 2008
    guess i'll just have to wait until audi decide to make them then.........
  7. Re: led tail lights
    May 2008
    Finland
    Or you can look at complete LED tail lights, not just the bulbs.
    If you get LED bulbs with the proper W21 body they will fit unless the LEDs forming the "bulb" shape are too big to fit into the holes on the cluster. However, most of the time LEDs produce very contentrated light and thus look bad in reflector type lights. They're also not bright enough for reverse lights even if you have, say, 30 LEDs in the same bulb.
    ____________________________________________
    VW Golf Mk.V 2.0tdi 4Motion
    VW Golf Mk.IV 1.4i
  8. Re: led tail lights
    Mar 2008
    Quote Originally Posted by Turbokiisseli View Post
    thanks for the advice guys,think i'm gonna keep using the normal bulbs for now,just have to make sure that they're not cheapies
  1. Aftermarket Tail Lights
    By 01V5 in forum Bora - 1998 - 2005
    Last Post: 22-04-2008, 06:54 AM
  2. A4 B7 Led Tail Lights?
    By poyorudo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2008, 02:44 AM
  3. Euro tail lights
    By dirtdude3g in forum Golf MK3 - 1993 - 1999
    Last Post: 19-12-2007, 09:24 PM
  4. Euro Tail Lights
    By Gee in forum Golf MK4 - 1999 - 2004
    Last Post: 20-11-2007, 12:33 AM
  5. A6 LED tail lights
    By toff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-11-2007, 09:05 PM
