Thread: Remote central locking - changed the battery but nothing happened!
  1. Remote central locking - changed the battery but nothing happened!
    I recently bought my golf and the remote central locking was working fine, but about a week ago it started to become a bit intermittent and I had to be closer to the car for it to work, and eventually stopped working altogether. I naturally suspected that the remote's battery had gone and have since changed it, but to no avail. Anybody have any ideas what might be the problem? Is there some special unlock code that you have to use if the battery is taken out of the key?
    P.S. I know this might sound stupid, but is there anyway to open the boot when the remotes not working? I can't find a boot catch anywhere!
  2. Re: Remote central locking - changed the battery but nothing happened!
    Angus, Scotland
    Hi there,
    You may need to re-sync your remotes to the car after changing the battery. The procedure for this should be in the manual.
    As for the boot, if you lift the VW badge there should be a key lock under there if I remember rightly. You need to get down on your knees and look straight up into it to see it though.
    Hope that helps
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  3. Re: Remote central locking - changed the battery but nothing happened!
    Plymouth
    Not sure about the key lock under the badge - I would go and look but it is dark outside!
    However, I do remember seeing in the manual that to open the boot you need to crawl in from the back seats, remove the circular disc in the trim inside the boot door, and do something in there.
  1. remote central locking on key
    By red.2 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2009, 09:48 AM
  2. keys, central locking to remote central locking!!!!!!!
    By Shakey mk4 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-03-2008, 01:35 AM
  3. A6 Remote Central Locking
    By paulhinton in forum Audi A4 - Archive Topics
    Last Post: 26-01-2008, 05:48 PM
  4. Coverting Central Lockin to Remote Central Locking
    By hoedawg in forum Golf MK4 - 1999 - 2004
    Last Post: 29-12-2007, 05:08 PM
  5. remote central locking
    By SonnyMC86 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-11-2007, 03:53 PM
