Thread: Oil Pressure problem
  1. Oil Pressure problem
    Hi everybody
    Can anybody help? I have a problem with with the oil pressure light comming on. I have read the other listings regarding this problem and would really appreciate any advice. I have had the problem since the test drive when i bought the car last summer. After taking the the car away all was fine then about a month later the problem fired up then went away then back., the problem is not consistant it my not happen for months then other times it can happen for the whole journey. VW took it in and could find no problem oil pressure was fine and so were the sensors.The car is a 1.8T 2001 with 60000 on the clock.
    Is this the sludge and pump problem??? or could it be an electrical fault??
    Dose anyone have any idea?
    Thanks James
    Aug 2006
    Notts
    That certainly sounds like an electrical fault to me. Intermittent faults are 99% caused by this.
    Clean the bulb contacts on the instrument cluster and the connection to the oil pressure sender on the engine. If you have a multimeter, check the resistance of the circuit. If its higher than tens of ohms, there is a potentially a broken conductor somewhere.
    Goodluck. Jp
    Thanks JP ill try that out
    silly question but are you using synthetic oil as required normal oil cooks and gums up the oil galleries etc,on most forums oil/water switches dont seem to last long and its not like they were produced for poundland
    I have a similar problem, or at least i think i do! Is the oil pressure warning light the one that looks like a thermometer and flahes red? Seems a bit weird because it looks like it should be a temperature gauge....
    ..its official, i'm a muppet. Its the coolant temp guage coming on on mine. Apologies.
  1. Oil Pressure Switch
    By e6m6a6 in forum Polo - Derby - Lupo - Fox
    Last Post: 05-06-2007, 05:42 PM
  2. 130 PD Turbo pressure problem fault code 17964
    By julesuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2007, 11:55 PM
  3. S4 Oil Pressure?
    By SnakeEyes in forum Archive posts
    Last Post: 30-03-2007, 06:28 AM
  4. Replies: 1
    Last Post: 25-03-2007, 11:03 PM
  5. Oil pressure problem
    By j1borman in forum New Member Introductions
    Last Post: 12-01-2007, 04:26 PM
