Thread: lamda sensor
  1. lamda sensor
    Jun 2008
    Mold
    Hi my 1.8t R reg is showing up open circuit on lamda sensor when using vag-com, can anybody tell me where this sensor is located and is it easy to change,
  2. Re: lamda sensor
    Crosby, Liverpool
    Exhaust manifold, its a fairly big,silver cylinder with a big grey wire comming out the top of it.Very easy to change 'should' just unscrew out of the manifold andbe a case of screwing another one in.However it might be seized so lots of WD40 and swearing may be needed.
    Audi A4 B5 1.6 -1998 <~~~ GONE
    Audi A4 B7 2.0 - 2005<~~~ GONE
    Audi A4 B5 1.8 T 1996 <~~~Here for now
  3. Re: lamda sensor
    Jun 2008
    Mold
    would this sensor being duff affect the performance of the car...
  4. Re: lamda sensor
    Crosby, Liverpool
    Yes - massivly.The lambda sensor tells the engine whats being sent out in the exhaust, and thus alters the air/fuel mixture accordingly.If your sensor is either on its way out, or dead then the the engine recieves no info on what is being emmited.It will then set the fuel mixture to a default setting as its better to be safe than sorry, but your performance will suffer.
  5. Re: lamda sensor
    Hi Chris,
    I am showing a 0030 fault for this sensor and can't even get my hands down to it on my 8v auto Bora let alone a spanner!
    Sorry for being dull, but is there a 'trick' to getting this sensor out?
  1. co or lamda sensor
    By doctorluv in forum Golf MK3 - 1993 - 1999
    Last Post: 24-04-2008, 01:31 PM
  2. Air Con - Sensor?
    By skipi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-08-2007, 05:53 PM
  3. Map Sensor?
    By DekHog in forum Polo - Derby - Lupo - Fox
    Last Post: 11-08-2007, 11:08 PM
  4. Thrust Sensor same as Map Sensor?
    By whistleblower in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-05-2007, 06:03 PM
  5. Lamda sensor
    By FEMI AJANA in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-05-2007, 11:03 PM
