Thread: Drivers door open switch not working
  1. Drivers door open switch not working
    Jun 2008
    Hi guys i have another problem with my 98 A6. The switch that detects if the driver door is open or closed doesnt work. This is causing a few problems from me leaving the lights on to nearly locking the key in the car.
    Ive worked out that the switch runs off the locking mechanism but where is it located ? Is it seperate to the lock ? Is it expensive to replace ?
    Lee
  2. Re: Drivers door open switch not working
    May 2007
    Switch is in the door lock, it's basically a microswitch incorporated in it.
    Normally the whole lock assembly is changed, not sure if switch can be changed on it's own.
  3. Re: Drivers door open switch not working
    Jun 2008
    [quote=snugglebum;197780]Hi guys i have another problem with my 98 A6. The switch that detects if the driver door is open or closed doesnt work. This is causing a few problems from me leaving the lights on to nearly locking the key in the car.
    I had 2 go on mine passenger side drivers and passenger doors.
    Yes its a new lock assembly for both i'm affraid cost me about £250 for 2 locks and fitting but solved the problem as keys locked in your car would cost about that for a locksmith or new widow + the inconvinience
  1. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
  2. passenger door courtesy light switch not working
    By barney2 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 14-02-2008, 05:18 PM
  3. Why won't my drivers door open?
    By carlyd28 in forum Golf MK2 - 1984 - 1992
    Last Post: 02-02-2008, 08:57 PM
  4. Replacing Drivers door arm rest trim and window switch
    By arcing in forum Audi A4 - Archive Topics
    Last Post: 23-08-2007, 12:56 PM
  5. Can't open drivers door 1997 Golf
    By Gina in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-07-2007, 01:15 PM
