Thread: 2.0fsi 53 Emissions problem?
  1. 2.0fsi 53 Emissions problem?
    Hi - Would appreciate any theories on what might be causing the three symptoms I have listed below;
    * Emissions/Engine Managment light blinking back on/off just after start up. (40% of the time).
    * Emissions light flashing on for 10 seconds between 4th/5th gear change @ 5000rpm. (only happend once so far).
    * Slight misfire type stutter when accelerating in high gear at low revs. (10% of the time).
    Audi have had my car all day and have just told me they can't find a fault this time.
    Two months ago they fitted a new coil to one of the cylinders which showed up as faulty after the Engine managment/Emissions lights came on when cruising in 6th at @3000rpm.
    My knowledge of cars is very limited so any theories would be appreciated.
    JP.
  2. Re: 2.0fsi 53 Emissions problem?
    Jun 2008
    HI, i have 03 2.0 fsi and i had similar problems. At first dealer said it was a sensor/valve. then it was my fuel pump, which seemed to cure for while but then my car shat the bed, turned out to be the coil, apparently they go all the time on this engine and rac always carry spares. If its still in warranty just keep badgering them mate i did.
  3. Re: 2.0fsi 53 Emissions problem?
    Thanks for the reply.
    The Audi service dept did hint at trying to get all three remaining old Coils (already had one replaced for this problem) replaced under the warranty at the same time, even if there not coming up as faulty.
    I think there starting to feel sorry for me! And are trying to cut down the number of visits to them I keep having to make.
    JP.
  1. Please Help Emissions/Misfire problem
    By sk1982 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-10-2008, 10:30 PM
  2. A3 2.0fsi Mpg
    By nickpw27 in forum Audi A3 - Archive Topics
    Last Post: 17-06-2008, 04:21 PM
  3. Emissions problem - help!
    By foxxy1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-04-2008, 11:47 PM
  4. 2004 A4 2.0FSi Idle problem..........
    By 4Ringsdrive in forum Archive posts
    Last Post: 21-12-2007, 05:26 PM
  5. Emissions Problem?
    By TwoFists in forum Audi A3 - Archive Topics
    Last Post: 27-10-2007, 03:10 PM
