Thread: Fault codes and problems....
  1. Fault codes and problems....
    Jun 2008
    Just had my car VAGCOM and I cross checking the part number from the below error. It seems the gearbox speed sensor is "dead" encased inside the expensive ECU. Car drives fine, no error codes on DIS but should I change the ECU at this time?
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 8E0 910 155 K HW: 01J 927 156 HH
    Component: V30 01J 1.8l5VT RdW 3120
    Revision: 00000004 Serial number: 00000000462115
    Coding: 0000001
    Shop #: WSC 00999 444 64523
    1 Fault Found:
    18201 - Transmission Output Speed Sensor 2 (G196): No Signal
    P1793 - 000 - -
    Freeze Frame:
    RPM: 1056 /min
    RPM: 800 /min
    RPM: 60 /min
    (no units): 2.0
    Torque: 22.0 Nm
    Temperature: 59.0°C
    T.B. Angle: 0.0°
    Bin. Bits: 1000 0 1
    Also what do the below codes mean as I cannot see any sensors inside the car which belong to an alarm system.
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1411
    Coding: 06890
    Shop #: WSC 00050
    Part No: 8E2959802B
    Component: Tőrsteuer.FS BRM 0003
    Part No: 8E2959801B
    Component: Tőrsteuer.BF BRM 0003
    Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0004
    Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0004
    3 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    Testing the car more and more I noticed a noise when one turns the steering wheel to pull away. Doesnt happen if your going straight but for left and right turns you can hear this clunk noise. Is this normal or is something worn like drop links or wishbones.
    This one will stump you all as I have no idea what the hell the noise was. Driving along normally went to adjust my rear view mirror and heard two mechanical noises. First from RHD then LHD but not as loud as the first time. Sounded like a robotic arm of some sort and figured it could be the headlight washers but I dont have them. Anyone have any ideas what the noise could be and if its dangerous
    Lastly if I drive over 60mph it seems there is quite a bit of feedback from the steering wheel. I had both front tires balanced and its still present but not as bad. Could it be the cheap tires I am using as I checked all wheel bearings which are fine.
    Billion thanks!
    J
  2. Re: Fault codes and problems....
    Dec 2007
    Suffolk
    The fault codes in the central convinence system are there to tell you what sensors have set off the alarm.
  3. Re: Fault codes and problems....
    Sep 2007
    The clunking noise you hear could due to using non oem parts for your brakes, I had the same noise when driving forward or reverse as i pressed the brakes or took off after using brakes. Local specialist checked ad found play in the pads poss discs, Changed for genuine ones and noise was gone. hope this helps
  4. Re: Fault codes and problems....
    Jun 2008
    Thanks smokey0123.....but I cant hear any siren or was this an "option" from Audi??
    fasttdi
    I will get my brakes checked out but it happens without me applying brakes.
    Anyone have any idea about the robotic noise I heard.
    J
  1. Fault Codes
    By jayde17 in forum Polo - Derby - Lupo - Fox
    Last Post: 07-03-2008, 09:47 PM
  2. Engine starting problems Vag code fault codes listed
    By MCCLATCHIE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-02-2008, 10:06 PM
  3. fault codes-vag
    By vw754 in forum VCDS - General Questions
    Last Post: 25-12-2007, 11:03 PM
  4. Fault codes ???
    By ronmcintosh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-12-2007, 11:58 AM
  5. vag com fault codes
    By Dozz in forum Audi A4 - Archive Topics
    Last Post: 10-06-2007, 12:45 AM
