Thread: Long Life Service Indicator
  1. Long Life Service Indicator
    Hampshire
    Hi All,
    I have had my A4 serviced today by an independent and they reset the service display (had 200mls left) but it now shows ---mls ---days, just dashes no numbers??
    Will this sort itself out after driving for a while??
  2. Re: Long Life Service Indicator
    Dec 2007
    Suffolk
    Yes that is normal
  3. Re: Long Life Service Indicator
    Hampshire
    Quote Originally Posted by smokey0123 View Post
    Yes that is normal
    Ahh ok thanks for that
    I have been reading up on longlife servicing and it seems as if the oil is measured in the sump for quality to set the service intervals?
    I guess with mine running LPG it should be longer than usual as at oil changes mine comes out the same as it went in!
  4. Re: Long Life Service Indicator
    Dec 2006
    Quote Originally Posted by blicky_1 View Post
    Hi All,
    Give it 200-500 miles and it will reset it self...
    More than likely will will go on the variable service rather than the long life unless they used the like of VAG-COM etc..
    if it comes back reporting that a service is due in 8000 miles to 12,000 miles they have just reset it via the standard cluster reset..
    That not a problem... just take a note of the mileage and date and arrange to re-service in 2 years or 20k miles..
    When it next alerts you that a service is due, hold the SERVICE button and trip reset and turn the ignition to reset it again.
    Rick
  1. VAG-COM Enable Long Life Service
    By rude_box in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-01-2008, 01:03 PM
  2. Long Life Service Indicator
    By gregk81 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-11-2007, 10:45 AM
  3. long life service reset
    By A6_JAck in forum VCDS - General Questions
    Last Post: 24-10-2007, 02:07 PM
  4. Long Life Service
    By bora(ing) nick in forum Bora - 1998 - 2005
    Last Post: 12-09-2007, 10:38 PM
  5. Long Life service
    By bora(ing) nick in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-01-2007, 03:33 PM
