Thread: T5 Door Hinge
  1. Angry T5 Door Hinge
    Jun 2008
    Hello all,
    Does anyone know where the bolt is located to remove the lower door hinge on the T5 ?
    There are 2 bolts and i already have the one accessable from the outside but there is one hidden which bolts from the inside somewhere I've had the wing off, rubber matting up but i still cant see it
    Thanks,
    Dan
  2. Re: T5 Door Hinge
    remove the plastic cover and bonnet release handle (there's a clip at the back of the handle have a good look because it easy to miss)pull the mat up pass the pedal you will see a earthing point on the right panel behind where the release handle would be, undo the 10mm nut now if you look to the left of the earthing point you'll see a round cover under the body sealant you'll have to dig it out put your finger inside and you'll feel the bolt
  1. Door hinge pins?
    By Mowzer in forum Golf MK3 - 1993 - 1999
    Last Post: 07-09-2008, 11:27 PM
  2. A3 Door Hinge Replacement
    By Nildefects in forum Audi A3 - Archive Topics
    Last Post: 01-03-2008, 02:36 PM
  3. Drivers door hinge adjustment?
    Last Post: 02-02-2008, 07:12 PM
  4. door hinge
    By 123singlemalt in forum Touran - Sharan - Caravelle
    Last Post: 17-12-2007, 03:56 PM
  5. Drivers door Hinge
    By mcgowan.b in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-11-2007, 04:54 PM
