Thread: Losing water on my t4 1.9 TDI
Results 1 to 10 of 11
  1. Losing water on my t4 1.9 TDI
    Jun 2008
    Hi everyone,
    My t4 1.9 TDI 163,000 miles has started to lose water but can't see from any obvious place, If i top it up to max level it'll drain to when the light flashes after a few days or about 300 mile journey then stays at that level ??
    cheers
    Ian.
  2. Re: Losing water on my t4 1.9 TDI
    Dec 2006
    Have a look at the back on the engine looking down to the gear box.
    There is a hose seal which seems to be failing around the 120k mark..
    Photo below..
    Rick
  3. Re: Losing water on my t4 1.9 TDI
    Co Durham
    I would check the radiator. Being aluminium, road salt corrodes them from the outside, usually the bottom corners. Look for coolant staining, it's easier to see with the bumper removed. A small leak won't leave puddles cos the heat from the radiator dries it straight away. I had to replace the rad on both my passat (110k) & wife's vento (90k) for the very same reason!
  4. Re: Losing water on my t4 1.9 TDI
    Jun 2008
    Quote Originally Posted by RickT View Post
    Photo below..
    Rick
    thanks for getting back to me, will have a look, much appreciated
    higgy
  5. Re: Losing water on my t4 1.9 TDI
    Jun 2008
    Quote Originally Posted by stonedagain View Post
    thamks for getting back to me, much appreciated, will have a look tomorrow,
    higgy
  6. Re: Losing water on my t4 1.9 TDI
    Dec 2006
    Quote Originally Posted by higgy1971 View Post
    higgy
    no worries... let me know how you get on..
    Rick
  7. Re: Losing water on my t4 1.9 TDI
    Hey Guys any more news on this, my a3 is doing the same. Neighbour who has an A3 also, had the same problem on the same day, he called up VAG and they told him it was a coolant issue, since then he's been fine.
    I have to fill up with water every few days, had a service in between but still it persists!!!!
    any help or guidance will be much appreciated, already spent £1500 on the car and want to avoid spending much more.
    thanks
  8. Re: Losing water on my t4 1.9 TDI
    Aug 2008
    Wales
    Had the same problem with my departed MkIV 2.0l golf. I would have to top the coolant up every day. The issue was the thermostat housing (right hand side of the block above transmission) which had cracked over time and was leaking coolant. I had this replaced and within two days, various hoses started rupturing and leaking. I replaced all the tired rotted hoses and all is good as new. As a tip, if you squeeze the main hose running from the block to the radiator a few times, if you have a leak which you can't see, you'll be able to hear it spitting and hissing through the break.
    Good luck.
    P.S, make sure the car has been standing for a few hours before you take any coolant hoses off. I didn't and scalded my fingers. Ouch!
  9. Re: Losing water on my t4 1.9 TDI
    Thanks Jimbo_S3 will take a look
  10. Re: Losing water on my t4 1.9 TDI
    Dec 2006
    Quote Originally Posted by misbah1977 View Post
    thanks
    Where abouts atre you based?
    Rick
  1. LT 35 Sdi losing water
    By TOOLMAN in forum The Commercial Range
    Last Post: 30-01-2008, 09:29 AM
  2. Golf tdi 115 bhp (1999)-losing water, help!
    By johne in forum Golf MK4 - 1999 - 2004
    Last Post: 14-01-2008, 11:24 PM
  3. MK3 TD (AAZ) Losing Water
    By Alun in forum Golf MK3 - 1993 - 1999
    Last Post: 06-01-2008, 06:04 PM
  4. Losing water....
    By mariacarroll in forum Audi A3 - Archive Topics
    Last Post: 15-09-2007, 03:33 PM
  5. Golf 1.9 GTTDi losing water
    By richiek in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-06-2007, 10:35 PM
