Thread: MK5 TID in to MK4??? Can it be done?
  1. MK5 TID in to MK4??? Can it be done?
    Can a Mk5 2.0Tdi 140bhp fit straight into a Mk4 GT Tdi 150?
    see my othre thread and u will see why?
  2. Re: MK5 TID in to MK4??? Can it be done?
    7 Post(s)
    Have not read the other thread.
    Personally, I think the PD150 is the better of the two.
    An engine swap of this nature is a huge undertaking, you will need to also swap the wiring looms, instrument cluster (assuming it will fit in the mk4), ecu and you may have to have some engine mountings fabricated.
  3. Re: MK5 TID in to MK4??? Can it be done?
    May 2007
    knee deep in clunge
    14 Post(s)
    very troll this post.
    1.9 IS FAR STRONGER AND MORE RELIABLE THAN 2.0 TDI
  4. Re: MK5 TID in to MK4??? Can it be done?
    7 Post(s)
    Read1976,
    Just so you know, that A8Tech blokey has worked for Audi (man & boy) and knows his stuff, also listen to Crasher, he may look like a tabby cat and can be a bit grumpy sometimes but he also knows lots.
    However, there is only one Troll !
    I think the point is, stick with the PD150 engine already in the car.
    Have you done any re-search regarding the infamous PD150 engine camshaft failure problem? That could be your issue. Still expensive but much cheaper and easier than an engine swap.
  5. Cool Re: MK5 TID in to MK4??? Can it be done?
    the 1.9 is a much stronger engine. I find that my Bora 130 Pd can keep up (and match) the new Seat Leon FR TDI which is the same engine as the 170 golf. So the 150PD should outperform the 140PD all day, plus it doesnt make sense why you would want to change the engine?
    not as simple as it sounds mate... keep the 150 is i were you.
  6. Re: MK5 TID in to MK4??? Can it be done?
    might as well close this thread. Cheers
