Thread: Audi A6 1999
  1. Angry Audi A6 1999
    My ABS idiot light is flashing in the middle of the speedo clock cluster - anyone have any ideas?
    Aug 2006
    Notts
    I'm not too sure about the later Audis, but my '88 90 had an abs fault but the light was coming on and staying on to indicate a fault. This may be the same for you. I've looked at autodata for the resistance of the abs sensors but it doesnt list it so i'd recommend checking each one to make sure they are all the same. If one is open circuit or v high resistance, thats at fault. Other things that can go wrong are the g-force sensor and brake pedal position sensor.
    If you tell me which engine you have i can look at the wiring diagram in more detail for you and suggest other things that may be at fault if you have no luck. By the way, does the abs still work with the light flashing?
    Jp
  3. A6 ABS
    jp - many thanks for you reply. I have had diagnostics done and it appears to be the ABS ECU unit which is not communicating with the main ECU. I have removed the electronic part of the ABS and sent it off to ECu - repairs.com. I hope they find the fault - apparently it is common with this ECU. the car is an A6 avant 2.5tdi 1999?
  1. Audi B5 1999 TDI Stalling
    By necstandards in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-10-2009, 08:45 PM
  2. Audi cab 1999 T
    By AUDICAB99 in forum 80 - 90
    Last Post: 30-04-2007, 11:18 PM
  3. 1999 Audi A6 1.8T SE Overheating
    By Cambrai in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-04-2007, 10:49 AM
  4. Audi a3 flip key 1999
    By mr_brett in forum Audi A3 - Archive Topics
    Last Post: 07-04-2007, 01:37 PM
  5. AUDI A6 1999 2.5 TDI
    By supermarket-sweep in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-08-2006, 08:44 PM
