Thread: audi a3 clutch slip
  1. audi a3 clutch slip
    Jun 2008
    GILLINGHAM DORSET
    hi kids,
    i own an 130tdi sport which i have just had chipped up tp 170bhp,i have 2 questions,first,will a cat bypass from millteck increase hp and why am i getting slight clutch slip in 5th and 6th gear when i boot it from about 70+??
    help,rob.
  2. Re: audi a3 clutch slip
    Jun 2008
    Usualy when the clutch slips it usually is too much torque its quite normal after a remap. Does it only do in 5th to 6? try driving off in second does it slip, or on low down in 3rd. If it does your clutch cant handle the torque. Whats millage has your vehicle done? You would possibly need a uprated clutch.
    The cheaper option is an light weight fly wheel that would stop the clutch slip but it will make the engine a lil louder.
    Millteck systems are good, you aint gna be expecting big power it just helps the engine breathe better and help you achive the existing bhp more constant rather than adding extra bhp. Usually a good combination is intake and out take, If you are getting and Millteck get an carbonio CAI (cold air intake) they sound fantastic and again helps engine brathe better.
    hope that helps.
  1. Clutch slip?
    By arl_gti in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2008, 10:59 AM
  2. clutch slip
    By andrewmorpeth in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-04-2008, 05:12 PM
  3. Clutch slip
    By markvw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-02-2008, 09:47 PM
  4. clutch slip / flywheel?
    By pawilson85 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-11-2007, 09:23 AM
  5. Clutch slip on chipped GT Tdi
    By Chris T O'Phart in forum Golf MK4 - 1999 - 2004
    Last Post: 25-10-2007, 07:02 PM
