Thread: Touran -sticky central locking problem
  1. Touran -sticky central locking problem
    Jun 2008
    Hi, one of the rear doors on my touran is failing to unlock. It started off just sticky and took a couple of goes to unlock, however now it seems to be stuck locked - I can hear the mecanism trying, but failing to unlock the door which can't be opened now in any way. I'm guessing I' won't be able to get the pannels off to sort this out without unlocking the door first
    So two questions realy:
    1- any suggestions on ways to "encourage" it to unlock?
    2- if / when I do get the I do get it open does anyone know what I need to do to stop it sticking, I've previously tried wd40 into the lock, which didn't seemt o make any difference.
    Thanks in advance
  2. Re: Touran -sticky central locking problem
    Jun 2008
    OK, further to this I now have the door unlocked by whacking the handle with my palm whilst unlocking. However my second question still holds, how do I get to the bit that's sticking?
    Any help appreciated
  3. Re: Touran -sticky central locking problem
    Aug 2008
    Hi, Did you make any progress. I'm having the same intermittent problem
  4. Re: Touran -sticky central locking problem
    Jun 2008
    WD40, bashing and pocking the mechanism all entirely failed to affect this issue. I did try to get into the door mechanism myself but you need special star shaped sockets which I don't have (they like to make it difficult these days)
    So, I eventually ended up taking this to the garage (I used local friendly garage rather than dealer). It turned out to be a problem with the lock/catch unit which needed replacing. Something about a part with several pieces of metal laminated together which were coming apart and sticking.
    By the time I got round to doing this the problem had unfortunately gone from intermittent to firmly stuck locked which added to the labour costs getting into it and also meant they slightly damaged the inner trim getting the door apart. On mine this was very, very slight but apparently this could have been a lot worse so I would definitely recommend getting this sorted while it still opens (nb, pumping the inner door handle whilst unlocking seemed the best way to get it open while it still would).
    In the end it cost me £200 - £80 part, £100 ish labour , plus VAT.
  5. Re: Touran -sticky central locking problem
    Aug 2008
    Many thanks for the useful information. I'll get it done before it gets any worse.
  1. Touran tailgate locking problem
    By SJH in forum Touran - Sharan - Caravelle
    Last Post: 21-04-2014, 01:03 PM
  2. Central locking problem
    By diamondbrit73 in forum 80 - 90
    Last Post: 26-06-2011, 02:46 AM
  3. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
  4. MK4 Central Locking Problem
    By nickelly in forum Golf MK4 - 1999 - 2004
    Last Post: 06-05-2008, 08:28 AM
  5. Touran central locking/water ingress faults
    By bigwull in forum Touran - Sharan - Caravelle
    Last Post: 23-12-2007, 05:59 PM
