Thread: Auto gearbox problem-need help
  1. Unhappy Auto gearbox problem-need help
    May 2008
    I have an odd problem with my 'W'reg 2.4SE A4 Avant auto box. After driving for approximately 30 mins the gearbox locks into high gear and ALL the lights on the gear indicator in the dash light up. Stopping the car and restarting resets the ECU and the car behaves perfectly normally. After testing it appears to be a fault with the gearbox ECU, but as it's a random fault, I don't want to spend lots of money on a new gearbox ECU unless it will cure the problem.
    Anybody got any ideas?
    Cheers,
    Chris
  2. Re: Auto gearbox problem-need help
    Chester-le-Street, United Kingdom
    what "testing" exactly? did you take it to a dealer or an independant specialist?
    if so,and they found it to be a fault with the gearbox control unit, why not believe them?
    why spend time and cash trying to change other things? what other things are thier to be changed that would cure a fault with the control unit?
    i would suggest a second opinion from a totally different reliable source,ie another garage.
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Auto gearbox problem-need help
    Ireland
    similar prob with my a6, if driving under 45 mph for a period of time it goes into limp mode as you described. Have changed MAP, MAF, Gear oil & Filter(This helped a little) but still have problem
  4. Re: Auto gearbox problem-need help
    May 2008
    Well Stewy, the "testing" was the usual plugging in of a diagnostics computer and it was taken to two independent specialists, one an Audi specialist and the other an auto gearbox specialist. What was curious was that the fault code showing was P0605 which is a fault with the engine ECU not the gearbox. And of course I believe them, I was there. As it is a totally random fault, I wanted to see whether it was a fault with the engine ECU that was causing the gearbox to go into safe mode.
    regards
    Chris
  1. auto gearbox problem
    By danglee in forum New Member Introductions
    Last Post: 12-06-2008, 07:52 PM
  2. 1.8 auto gearbox problem
    By hocks172 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2008, 01:33 PM
  3. Auto/tiptronic gearbox ecu problem
    By jewelldo in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 09:57 PM
  4. Auto gearbox problem with 02 TDI Passat
    By Kaiser2000 in forum Passat - Archive Topics
    Last Post: 11-11-2007, 04:26 AM
  5. 51 2.0S auto gearbox problem
    By kharva007 in forum Passat - Archive Topics
    Last Post: 09-02-2007, 02:27 AM
