Thread: Can this be changed?
  1. Smile Can this be changed?
    stevee_p Guest
    Hi all
    I have a mk4 gttdi 115 pd, and (same on most VAG i believe) when you unlock the car with the central locking, then don't open the doors, the car locks itself after about 30 seconds.
    Is it possible to turn this feature off? I was in the middle of nowhere when my friend locked the keys in the boot due to this! Anyway, the RAC fixed that, but its the sort of thing i can see happening again if im not careful!
    I believe there may be some sort of way to do it by putting the key in the ignition and pressing the key fob twice etc, but not sure how?
    Any thoughts much appreciated!
    Stevee_p
  2. Re: Can this be changed?
    Edited
  3. Talking Re: Can this be changed?
    May 2008
    ESSEX
    yeah mk4 tdi does the same 30 secs dont open door it relocks
  4. Re: Can this be changed?
    May 2007
    your car should not do that, if you unlock it and don't open the doors then it relocks itself, once you open the doors it wont relock itself, this is ment to stop you locking the keys in it, also you car should know if the key fob is inside the car and wont lock itself. i think you are able to reprogram it so that it wont do it and you can change it so that you only have to press the unlock button once and all the doors will open.
  5. Smile Re: Can this be changed?
    May 2008
    ESSEX
    Quote Originally Posted by v6dub View Post
    yeah thats it if you unlock it and dont open any doors within 30 secs it relocks it self, but once you have opened a door and reshut its fine.
    i also press unlock once and drivers door opens press again and they all open i think you can change this setting
  6. Re: Can this be changed?
    2001 Post(s)
    It only knows the keys are in the car if they are in the ignition.
  1. Please Help changed the MAF now I've got juddering
    By Claire_768 in forum Audi A3 - Archive Topics
    Last Post: 23-06-2008, 03:19 PM
  2. CV changed and ABS light went on
    By Martas in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-05-2008, 11:32 PM
  3. Valve seal to be changed
    By chicco in forum Polo - Derby - Lupo - Fox
    Last Post: 22-05-2008, 04:26 PM
  4. 1.8t changed oil
    By m4xmw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-09-2007, 05:47 PM
  5. How often should the oil be changed?
    By SammyP in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-05-2007, 01:21 PM
