Thread: Fault Code PO411 - Secondary Air Solenoid Valve (SASV Y75)
  1. Fault Code PO411 - Secondary Air Solenoid Valve (SASV Y75)
    Mar 2008
    Teeside, UK
    Hi there, i keep getting a fault code via vag com from my A4 1.8T 2002 about a secondary air flow solenoid valve.
    Does anybody know anything about this?
    A friend of mine had a similar prob with his Seat Leon, it has the same 1.8T engine as my Audi, he added some injector cleaner twice and that cleared it, i have tried this but the engine management light keeps coming on every month or so and the same code keeps appearing again.
    Where is this valve? is there a fix or will i have to replace it?
    Andy
  2. Re: Fault Code PO411 - Secondary Air Solenoid Valve (SASV Y75)
    Were I is Now
    Probably a split in one of the small air lines - no easy way to test which one, but you can bet it will be the least accessible/last one you try....had mine at the dealers for 2 days while they looked for it....still under warranty back then.....
    2010 S4 in exclusive classic red and every option under the sun...as well as my 80 cabriolet 2.6e auto fun day car...not forgetting a slightly Smashed but saved waiting for some repairs 01.5 B5 A4 2.4SE Tip - Votex body kit, Hidden Microwave PDC, Pirelli X-Pressure TPMS, Hardwired Bel RX65e, Lamp Guards...and the exclusive Red Logo Audi Sport Valve Stem Caps!
  3. Re: Fault Code PO411 - Secondary Air Solenoid Valve (SASV Y75)
    Mar 2008
    Teeside, UK
    Quote Originally Posted by cactusgreen View Post
    Thanks Cactus, where are these lines? under the air filter housing?
    Andy
  4. Re: Fault Code PO411 - Secondary Air Solenoid Valve (SASV Y75)
    Were I is Now
    It's the small yellow ones where you can see them - some have a fabric? covering.....and they are all over the place!! My leak was at the back of the head...so the invoice says....
  1. Fault Code 00268 Salanoid Valve 6-N93 ?
    By mck.motors in forum VCDS - General Questions
    Last Post: 06-05-2010, 09:48 PM
  2. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
  3. Fault Code 00268 Salanoid Valve 6-N93 ?
    By mck.motors in forum Archive posts
    Last Post: 13-10-2007, 12:53 PM
  4. Fault Code 00268 Salanoid Valve 6-N93 ?
    By mck.motors in forum Touran - Sharan - Caravelle
    Last Post: 12-10-2007, 03:32 PM
  5. Audi A6 1.9 tdi '04, EGR valve fault code.
    By mike audi a6 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 18-12-2006, 02:10 AM
