Thread: Coolant light still on after topping up with coolant
  1. Coolant light still on after topping up with coolant
    Mar 2008
    I have this prob on my A4 1.8 1997. Will it sort itself out, does it need a vag com reset, or could it be something else?
    Ive filled up to the max line in the expansion tank, what could the prob be? Cheers
    Rich
  2. Re: Coolant light still on after topping up with coolant
    Hi You may have a faulty sensor in the expansion tank.Remove the contact and bridge the two wires,if the control light goes out,replace the tank.
  3. Re: Coolant light still on after topping up with coolant
    Mar 2008
    Hey thanks for that, im getting paranoid the water pump is shot, but all the hoses are hot so I think that's fine.
    I had a new stat and temp sensor a few months ago, and the car runs bang on 90 degrees.
    Is the sensor the one underneath the tank? Ill try a spray of contact cleaner and see what happens.
    Many thanks
  4. Re: Coolant light still on after topping up with coolant
    Mar 2008
    Update...
    took the expansion tank off, gave it a good clean out with the shower head and washing up liquid, got loads of crud out.
    Light has now gone out, so must have been a dirty sensor. Result
    Rich
  1. T5 2.5 130 water coolant loss and oil light.
    By hocks172 in forum The Commercial Range
    Last Post: 06-10-2010, 07:09 PM
  2. Coolant LIGHT!!
    By jasw in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-07-2009, 02:52 AM
  3. Topping up coolant Fluid
    By mclean1979 in forum Polo - Derby - Lupo - Fox
    Last Post: 11-05-2008, 09:14 PM
  4. Coolant Warning Light
    By wanna in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-03-2008, 09:32 PM
  5. Low engine coolant temperature, which coolant to use
    By rhencullen1989 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2007, 11:35 AM
