Thread: High tick over, 2.6 litre
  1. High tick over, 2.6 litre
    Jun 2008
    My father-in-law has a 1997 Audi A4 estate with a 2.6 petrol engine. He has recently had trouble with it ticking over very fast when it is cold (1400 rpm). He took it to a garage (not Audi dealer) and they plugged in a diagnostic computer but found no faults. They have cleaned up the throttle body which was apparently very dirty and fitted a new battery as his had a dead cell. However the fault remains, does anyone know if there is a common complaint with these?
    The garage have suggested he renew the temp sensor because it s quite cheap but I feel they are maybe just guessing. If guessing is the game I would guess at either the airflow meter or perhaps even the lambda sensor.
    Anyone with better ideas than that I would love to hear from you as he does not have enough money to just replace everything and hope to repair it by accident. Thanks.
  2. Re: High tick over, 2.6 litre
    london/ UK
    Did they do a throttle body recalibration AFTER they cleaned it and replaced the battery ? If they did, chances are that the idle control valve might be faulty and is built into the throttle body housing wich means a new throttle body is required....expensive !
  3. Re: High tick over, 2.6 litre
    Jun 2008
    Adam,
    Funny you should ask, they did do a recalibration after renewing the battery and said at the time that it should have done it itself automatically.
    Thanks for the reply.
  1. 1.8 to 2 litre conversion.
    By funkrocker1 in forum Golf MK2 - 1984 - 1992
    Last Post: 02-05-2008, 03:05 PM
  2. Evap Valve .... Tick...Tick....Tick
    By J..M in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-04-2008, 05:20 PM
  3. LPG Autogas - have you done it & £ litre
    By robert-bristol in forum Chat - Anything with wheels
    Last Post: 17-01-2008, 03:38 PM
  4. High tick over?
    By Hayden in forum 80 - 90
    Last Post: 28-12-2007, 07:54 PM
  5. Indicator 'tick tick' noise
    By avaghela in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-07-2007, 10:21 PM
