Thread: remove cupholder
  1. remove cupholder
    Oct 2007
    kent
    please help, my front cup holder is broken on the left side, and stuck in the dash.
    sometimes when "wiggled" it comes out, but still cant be used as it not stable.
    how easy is it to take out, might be able to mend it if it's out of the dash.
    don't particularly want to use it as a drink holder, it just annoys me that it broke!!
    has been broke since i had the car and never bothered about it.
    i know they are not that expensive to replace from Vag-parts.
    Stu
  2. Re: remove cupholder
    Yorkshireman Guest
    It want to remove the cup holder and replace it with a new one, you'll need to do the folloiwng
    Clip of the plastic trim of the centre console which sits just above the cup holder and coin holder tray. The best way to remove this is to put a screwdriver on bot sides and push towards you as it slides out more that clipping out.
    You'll then need a thin straight screwdriver. You'll see two little clips that hold the drink holder compartment into the din cage. You'll need to press these clips down and the cup hold compartment should slide out. The two clips are not very visible so you may need a torch
    The new cup holder just slides in and will clip in place. Hope that helps
  3. Re: remove cupholder
    Oct 2007
    kent
    Quote Originally Posted by Yorkshireman View Post
    cheers
    are you talking about the trim strip (mine's black, but maybe wood effect or aluminium etc) that runs along the dash and over the glove box??
    i know the door trim equivalent comes off to gain access to door trim clips, as the weather strips had to be removed for my window tints to be applied
    Stu
  4. Re: remove cupholder
    Yorkshireman Guest
    No, you do not need to remove that trim.
    The trim i refer to is part of the centre console. If you take a look at your cup holder and i assume you've got a coin holder next to it, its the plastic trim just above these two items which is part of the centre console.
    You'll need to remove this trim to remove the cup holder. Any doubts, give us a shout
  5. Re: remove cupholder
    Oct 2007
    kent
    saw what you mean today
    thanx, hadn't been in the car for a couple of days when i posted up.
    i'll give it a go
    Stu
  6. Re: remove cupholder
    Dec 2007
    this shows tray removal its the same for cup holder
    http://www.audiworld.com/tech/int60.shtml
  7. Re: remove cupholder
    Oct 2007
    kent
    cheers for that Bez
    had a look earlier, but got extremely P I $ $ E D off when i looked up and had a parking ticket on my windscreen!!!
    turned out it had the wrong reg number on it and i panicked about nothing, but wasn't in the mood to carry on!!
    I'll take another looky tomorrow, but if there chance of breaking it further, i'll just leave it as is!!
    Stu
  1. How do you remove the scuttle?
    By highwire in forum Bora - 1998 - 2005
    Last Post: 08-05-2008, 01:22 PM
  2. How to remove
    By dwight in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-04-2008, 12:36 PM
  3. MAF!! How to remove??
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-04-2008, 07:01 AM
  4. How to remove Key Scratch
    By byrlord in forum Audi A3 - Archive Topics
    Last Post: 21-02-2008, 05:49 PM
  5. front cupholder
    By stevjoe in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-06-2007, 09:24 PM
