Thread: S-Line Suspension Versus Standard
  1. Question S-Line Suspension Versus Standard
    Hello All,
    I have a 04 A4 1.8T. It is just the standard version. First off I found someone selling a set of S-Line Springs. Will these drop my car by much or are they the same as the standard springs. Does the S-Line model have different shocks too?
    Also there is another person in Dublin selling 18" Audi TT alloys. They look immaculate and are described as Audi RS4 9 spoke original. Will wheels that fit an Audi TT fit onto an A4.
    Thanks for the help.
  2. Re: S-Line Suspension Versus Standard
    I think the audi TT alloys should fit... only diffrence i know of is the tyre width... normal a4 is 235 audi TT is 225, dosent really make a noticable diffrence 2 b honest
    Audi a4 1.9tdi 6 Speed Sport 53 reg
  3. Re: S-Line Suspension Versus Standard
    Cheshire
    If they are genuine Audi wheels from a TT then they won't fit. But if they are reps then they'll most probably be multi-fit and thus would probably fit an A4. I could be wrong in thinking that the S-line suspension is the same as the sports, in which case it's slightly stiffer and 15mm lower than standard.
    I've got my go go go go go go go go go go gadget flow.
  4. Re: S-Line Suspension Versus Standard
    Think the offset is different on the TT and A4.
    Thought the s line and sport suspension is 30mm lower??
  5. Re: S-Line Suspension Versus Standard
    TT alloys are defo original, so rules them out.
    Will I get away with using S-Line spings on the standard shocks though?
    Thanks for the input.
    Marcus
  6. Re: S-Line Suspension Versus Standard
    Jun 2008
    I was under the impression the S line springs are 20mm lower than standard. however, was told that there are several different S line springs ranging in different drop levels.
    I too would like to know if the shorter S line springs can work with OE shocks. understand life of the longer OE shock will be reduced.
    J
    Quote Originally Posted by thecuse View Post
    Marcus
  7. Re: S-Line Suspension Versus Standard
    Dec 2007
    Aberdeen
    the sport/s-line includes a unique damper and coil package. Id recomend both.
  1. A4 1.8t S Line Quattro 2004 - Suspension too hard!!!!
    By Gurd in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-11-2009, 02:31 PM
  2. Experiences between S Line and 'normal' Sports suspension
    By YHuhtala in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-05-2008, 03:42 PM
  3. S-line 30mm suspension + 19'' Wheels
    By HighwayTG in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-05-2008, 04:41 PM
  4. S Line/Sports Suspension
    By mkc in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-04-2008, 06:07 PM
  5. A6 on 18s with standard suspension for towing ?
    By ajc in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-12-2007, 12:12 AM
