Thread: A6 not used for 3 weeks, now won't start or do anything
  1. A6 not used for 3 weeks, now won't start or do anything
    emmaA6 Guest
    Neither key will unlock the doors (but managed to open the drivers one manually), and when I put the keys into the ignition nothing happens at all.
    Is this a key problem, or a battery problem, or soemthing else altogether?
    I need to sort it out ASAP, and as cheaply as possible. I'm due to trade the car in as part-exchange on another car on Tuesday.
  2. Re: A6 not used for 3 weeks, now won't start or do anything
    May 2008
    Lincoln, UK
    i had the exact same problem. what model / year is your car ?? we have a 2002 1.8T . stuck it in garage for 3 weeks prior to selling and same happened. flat battery - or should i say battery lower than on-board systems would like so total shutdown. simple solution - remove all connections to battery and charge battery. if you dont disconnect form the car it will have a wobbler and lots of warning lights and scary noises !!!!. mine seems to be OK now. leaving it connected to car confused me for ages and my automatic battery charger seemd to hink the batt was full when it wasnt. think it got confused by the cars electronic systems.
  3. Re: A6 not used for 3 weeks, now won't start or do anything
    emmaA6 Guest
    It is a 2002 1.9 Tdi.
    Problem now solved (fingers crossed). We've replaced the battery and all seems well.
  4. Re: A6 not used for 3 weeks, now won't start or do anything
    Mar 2008
    11 Post(s)
    I would probably check/test to see the source of the drainage... 3 weeks is not a long time to let the battery die
    Did you leave something on accidently like a light?
    Could just be a dodgy battery that was going to die soon but all the same, do check!
  1. TDI pulley/water pump gone in 2 weeks of ownership!
    By bonerp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-10-2007, 04:23 PM
  2. Help - urgent advice please. Part not available for 3 weeks!
    By hc25036 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-07-2007, 08:34 PM
  3. This weeks funnies and shock videos
    By mikeyboy82 in forum Chat - Completely Off Topic
    Last Post: 18-04-2006, 07:24 PM
  4. vw making me wait 3 weeks for part!!!
    By andy79 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-02-2006, 09:52 PM
  5. This weeks funnies
    Last Post: 23-01-2006, 10:32 PM
