Thread: Air con Fans
  1. Air con Fans
    May 2007
    Could any tell me if both radiator fans should start up when i press the air con switch inside the car?
    The car is a 2000 golf gti 2.0.
  2. Re: Air con Fans
    Aldershot, Hants
    When I turn my A/C on both fans start.
    Mine is a 1999 golf gti 1.8t with climate control
    Quote Originally Posted by topgunmatt View Post
  3. Re: Air con Fans
    Bath, Somerset
    Both mine run too and I have Climate Control. If only one runs then sounds like you need a new fan.
  4. Re: Air con Fans
    Jul 2008
    I have had a problem with the ac fan, one failed to work when the car started up with ac. Now it has been replaced the ac works much better than before especially when at slow speeds, and is much colder. Mine was over 100 pounds from vw however. I think the big one was the one that stopped working on mine
  1. twin fans on rad
    By charles0106 in forum 80 - 90
    Last Post: 26-06-2008, 10:23 PM
  2. Hi All Audi fans
    By Ash333 in forum New Member Introductions
    Last Post: 22-03-2008, 11:33 PM
  3. cooling fans
    By dazzer in forum Golf MK4 - 1999 - 2004
    Last Post: 16-03-2008, 09:11 PM
  4. cooling fans
    By simon74 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-02-2008, 11:55 PM
  5. fans on radiator
    Last Post: 07-10-2007, 06:38 PM
