Thread: 12v power source
  1. 12v power source
    May 2008
    Where's the easiest place to pick up a 12V permanent and 12v switched power supply in the dash/centre console/glovebox area ? Cigarette lighter, radio, glove box light ?
    Looking at fitting a car kit and easiest tidy way of hooking it up.
    Ta, John
  2. Re: 12v power source
    To get both permanent and switched the best and easiest place would be to tap into the back of the head-unit.
    This will drain a little power from the stereo though so depends whether you like to listen to the stereo loud all the time. If you do then run a dedicated power lead straight from the battery to your stereo.
    When I’ve put sat-navs etc in I always just use the switched feed to the cigarette lighter as these are never normally used, this way the power comes on when the ignition is turned on.
  1. 12v source near the centre console
    By Pidge_MKV in forum Golf MK5 - 2004 - 2009
    Last Post: 29-04-2008, 05:26 PM
  2. external mutimedia source
    By colinandlesley@ in forum Eos
    Last Post: 19-04-2008, 12:57 PM
  3. Source for Front Suspension Arms Kit?
    By shaiboy_uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 01:50 AM
  4. No power to cigarette lighter so no power to sat nav...
    By Dfardon in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-12-2007, 09:48 AM
  5. Power source for Satnav / Phone Power
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 07-02-2007, 12:43 PM
