Thread: Water in rear passenger footwell
  1. Water in rear passenger footwell
    Dec 2006
    Recently have noticed a little water in the rear passenger footwell of my 1.8 A4 Avanti Turbo Sport 1999, yesterday went to check it and it is full of water, it is only in that footwell the rest of the car is dry, cant understand where it is coming from?, can anyone help.
    Oct 2005
    Pop the bonnet and check the area around the battery to see if it's full of water. If it is, you have blocked drainage bungs.
    There's posts around on how to clear them - let me know if you need any pointers.
    Aug 2006
    Scotland
    Check your sunroof drains too (if you have one).
    Jo
    Have a look at the rear window washer pipe... on my one there is a joint, scarilly enough, just above a connector block in the wiring loom. Some time ago it came apart and filled both footwells with the blue stuff! (it runs down the left side of the car through the passenger footwells)
    Dec 2006
    Kent and Guernsey
    Quote Originally Posted by avantiblue View Post
    Try http://www.weirdlittlebiscuit.com/passat/leak/
    Sure it's a Passat, but at least it shows a possible problem on your car - drain holes.
    This may be combined with a leak at your pollen filter holder. ( If you unbolt the holder, take care, the bolts are made of soft metal, so do not over tighten. )
  1. WATER in passenger side... Near top of footwell
    By Anzee in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-01-2011, 06:43 PM
  2. Water in Passenger Footwell
    By Paulpro in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-03-2009, 11:52 PM
  3. Water leak into front passenger footwell
    By Basil_Brush in forum Touran - Sharan - Caravelle
    Last Post: 17-12-2007, 11:33 PM
  4. Passenger Footwell Water Leak...
    By mkpp786 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-06-2007, 02:49 AM
  5. Water in Passenger Footwell.Audi A4
    By ben.yule in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-11-2006, 10:00 PM
