Thread: Vag Com/Vista com ports problem
Results 1 to 10 of 18
  1. Vag Com/Vista com ports problem
    Jun 2008
    Hi everyone,
    This is my first post, sorry its such a complicated one!
    I have purchased a USB OBD2 cable off ebay to have a play around with the vag com shareware (409-1).
    I am using vista and running the program as administrator and in xp compatibility mode.
    The cable drivers installed ok but on COM12. Therefore, following the directions on this site I changed this to COM1.
    Everytime I try to test the com ports I receive the message "Port already in use", or if I remove the cable I get "Port does not exist".
    I have tried changing to ports 1-4, ensuring none of them are in use but still receive the same message.
    When pressing the LED's option I get the message "Port status: Inaccessible".
    I have tried all this while connected to my car but still with no joy.
    I am sure this is a vista problem as on xp it says "Port status: OK" without the cable even being plugged in.
    Can anyone help please?
    Thanks in advance
    Mike
  2. Re: Vag Com/Vista com ports problem
    Jan 2008
    Angus, Scotland
    Hi Mike,
    You say you are connected to the car, is the ignition on?
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  3. Re: Vag Com/Vista com ports problem
    Jun 2008
    Hi Paul,
    Yes the engine was running, I think the problem I have is vag com isnt recognising the interface even though the com ports match.
    I can run the same setup on xp and even with the interface unplugged, the test reports the port status is ok. Unfortunately this doesnt happen on my laptop which has vista.
    Thanks for your reply
    Mike
  4. Re: Vag Com/Vista com ports problem
    Dec 2007
    Sheffield
    I had a similar problem when I installed VAG COM in vista where it installed on to COM6. I changed the port to COM2 which was nt in use and it worked fine. Not sure why its not working on COM1 if it definetly isnt showing as being used in device manager. I cant see what would be hogging all of the COM ports. Have you tried uninstalling VAG COM and all the cable drivers and reinstalled?
  5. Re: Vag Com/Vista com ports problem
    Jun 2007
    A, A
    What USB to serial drivers did you use ?
    Just another B7 Estate
  6. Re: Vag Com/Vista com ports problem
    Jun 2008
    Quote Originally Posted by brentos2004 View Post
    Yes I uninstalled and even tried installing directly to the desktop as I had read somewhere about restrictions in the program files directory.
    One thing I should mention actually, when selecting the com port through device manager, even though it shows it as not in use, i still get the message "This port has been opened by another application. Renaming the port may have an unpredictable effect on the other application. Do you wish to continue?". After selecting yes it changes and displays the new COM number. Did you receive this message?
    Also, if I test a com port through vag com that is not in use i get "Port does not exist".
    Quote Originally Posted by mluton View Post
    I'm using the ones supplied on the disc from ebay, is there an alternative?
  7. Re: Vag Com/Vista com ports problem
    Jun 2007
    A, A
    I used this one for XP, but states its vista compatible:
    http://www.ftdichip.com/Drivers/VCP.htm
  8. Re: Vag Com/Vista com ports problem
    Dec 2007
    Sheffield
    I only got the port does not exist error on COM1 for some reason but worked fine on COM2. I let vista install the driver for the cable itself as this worked alot better than using the driver supplied on the cd. I would definitely try that first and see if that sorts it out.
  9. Re: Vag Com/Vista com ports problem
    Jun 2008
    Spot on brentos!
    Had to uninstall the driver through device manager and made sure I selected the option to delete the driver aswell. Then after connecting the cable again, vista downloaded and installed its own set of drivers. I then changed the com port to COM2, and voila, the test in vag com reported port ok!
    Thanks a tonne for everyones help, would never have solved this on my own!
    I've already managed to find some fault codes! Although not sure if thats such a good thing.
    Mike
  10. Re: Vag Com/Vista com ports problem
    Dec 2007
    Sheffield
    Spot on brentos!
    Mike
    Glad you got it sorted Mike
    Brent
  1. Vista is annoying... need XP
    By Loofer in forum Home Tech Shed
    Last Post: 08-06-2009, 05:05 PM
  2. VAG COM on Windows Vista
    By Marc111111 in forum VCDS - General Questions
    Last Post: 29-09-2008, 08:48 PM
  3. VAG-COM on Vista
    By sooty in forum VCDS - General Questions
    Last Post: 03-03-2008, 01:16 AM
  4. Windows Vista
    By stuart in forum Home Tech Shed
    Last Post: 10-09-2007, 09:49 AM
  5. Windows Vista
    By Foxcub in forum VCDS - General Questions
    Last Post: 10-04-2007, 10:50 AM
