Im after a little bit of help / advice for my S3!
The problem is:
I pressed the clutch pedal (as normal) just after starting the car obviously to put it into gear and it made a 'thud' kind of noise and stayed at the bottom. I found a broken piece of plastic on the floor just under the clutch pedal which has definately got something to do with the clutch pedal.
Now the pedal stays put right at the bottom near the floor and only comes back up when you pull it up!
Even with the pedal pressed in the clutch does not work what so ever!
Any ideas on what this problem is?
All help will be greatly appreciated!!
Thanks in advance
