Thread: Golf MK3 1996 Driver Window Problem
  1. Golf MK3 1996 Driver Window Problem
    Mar 2006
    Dear All,
    I have a Golf MK3 2-door Golf GTi with electric windows. The driver side window suddenly stopped working. I took this weekend to take a closer look.
    The symptoms are that when I wish to open the window I can hear a click shortly followed by another and the window does not wind down! I suspect the motor is dead but to verify that I decided to take a closer look.
    After an hour struggling with it, I eventually managed to get the door panel off. There appears to be 5-bolts holding the motor to the door panel. Considering the window is still up, I was reluctant to remove the 5th bolt - worried just in case the glass fell? Is that the right way to remove the motor? I do have a Haynes manual but the graphics in that are quite poor.
    Perhaps somone would kindly give me instructions on how to take the motor out to then replace it with a new one assuming the motor is faulty? I did not want a situation where the glass could not be put back in if I forced out the motor by removing all 5-bolts.
    Of course I am open to *any* suggestions if the symptoms I describe do not indicate a motor problem. It sounds jammed or busted from the diagnosis I have done.
    I have left the door panel off for the time being and am driving the car so if anyone can help me save a lots of ££'s to fix the problem I would gladly appreciate it.
    In anticipation and kind regards,
  2. Re: Golf MK3 1996 Driver Window Problem
    Oct 2005
    This is a forum for posting guides on Detailing.
    Post moved from here to Golf MKIII section
  1. Driver side window
    By Johnny C in forum Golf MK3 - 1993 - 1999
    Last Post: 08-02-2008, 11:36 AM
  2. Driver side window won't open!
    By KLO1 in forum Audi A3 - Archive Topics
    Last Post: 07-10-2007, 05:17 PM
  3. driver side electric window
    By sumanb82 in forum Audi A3 - Archive Topics
    Last Post: 12-04-2007, 10:23 PM
  4. Mk3 Golf Tdi (1996) acceleration problem
    By Octavius in forum Golf MK3 - 1993 - 1999
    Last Post: 28-03-2007, 05:50 PM
  5. HELP !!!! Passat Driver doorlock & window
    By Enceem in forum Passat - Archive Topics
    Last Post: 19-10-2006, 01:54 PM
