Thread: Adjusting Front Bumper Height
Results 1 to 10 of 12
  1. Adjusting Front Bumper Height
    Angus, Scotland
    Hello One and All,
    Finally got my car back from Audi after them sorting all the problems that I had with the car when I picked it up.
    One of the things they wre doing was replacing the front grille as it was cracked, only a small crack but thought I'd get it changed anyway.
    When I picked the car up I noticed that the gap between the bonnet and the bumper was quite large, as in I could fit my finger tip comfortably in it!! It wasn't like that before, and I really can't be ***** putting it back into them again.
    So, how easy is it to adjust the height of the front bumper?
    It is definately the bumper as there is a gap between the headlights and the bumper too!
    Cheers in advance guys
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  2. Re: Adjusting Front Bumper Height
    133 Post(s)
    1983 Post(s)
    It is a lot of work, it means removing the cover and releasing the impact absorber mounts and lifting the front panel up and then test fitting the cover and is a bit hit and miss, often taking a few attempts to get it right.
  3. Re: Adjusting Front Bumper Height
    Angus, Scotland
    Hmm... sounds like a job for the numb nuts that got it wrong in the first place then!!
    Can you confirm that the Audi specs for the gap are 4.5mm +- 0.5mm??
    Going to go mental at them tomorrow!!
    Paul
  4. Re: Adjusting Front Bumper Height
    Angus, Scotland
    Crasher,
    Why would they have adjusted the impact absorber? All they were doing was replacing the front grille not the entire bumper! Is that required to replace the grille?
    Paul
  5. Re: Adjusting Front Bumper Height
    133 Post(s)
    1983 Post(s)
    4.5-mm +/-0.5-mm.
    There are adjusters on the impact absorbers that move when you take off the cover.
  6. Re: Adjusting Front Bumper Height
    Angus, Scotland
    Hey Crasher,
    Had the car down at Audi yesterday lunch time and the head monkey is saying that there isn't any adjustment he could do!!
    On the attahced image I have a problem with gaps A and B. They are both around 11mm. Under the headlights there is a gap of around 5mm at the centre of the bumper. The side gaps are fine.
    They're apparantly going to get back to me tomorrow!! Wonder what they'll try and fob me off with now. Sigh!!
    Paul
  7. Re: Adjusting Front Bumper Height
    133 Post(s)
    1983 Post(s)
    I would delete that attachment if I were you; Stuart may get grumpy about an ELSA attachment. If you have ELSA, you can see the adjustment procedure.
  8. Re: Adjusting Front Bumper Height
    Angus, Scotland
    Hi Crasher,
    Cheers, have removed the attachment.
    I think I can see the procedure on there, but my question is shouldn't the whole bupmer be out of alignment, or would the arch bolts be enough to hold the bumper in place at the side even if the centre part is out of alignment?
    I think I'll wait and see what Audi come back with tomorrow and take it from there.
    Cheers for your help
    Paul
  9. Re: Adjusting Front Bumper Height
    133 Post(s)
    1983 Post(s)
    There is a small amount of slack on the bumper to wing studs but they tend to self align.
  10. Re: Adjusting Front Bumper Height
    Angus, Scotland
    Now that I've got batteries in my camera I have taken a few piccies to show what I mean. Can't beat piccies!! And its the first ones I've actually taken of the car since I got it... really should have cleaned it first though!!
    You can see the gap at the grille and next to the headlights but the bonnet is flush with the wings and the bumper is flush with the wings too!!
    Should Audi be able to fix this? And should they have caused this in the first place by replacing the Grille??
    Paul :biglaugh
  1. front bumper mod a3
    By hazhammy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-04-2008, 07:51 PM
  2. Front Bumper
    By sdk778 in forum 80 - 90
    Last Post: 04-03-2008, 06:28 PM
  3. A4 TDi Sport Ride Height - different front / back
    By RidwarePhil in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-01-2008, 08:24 PM
  4. front bumper
    By robbiedobbiedo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-01-2008, 12:22 PM
  5. Someone With a R32 Front Bumper
    By FLASH in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2007, 01:28 PM
