Thread: Polo wont start
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. Unhappy Polo wont start
    Saltash
    My 96 Polo 1.4 was driving okay then started to lose power over a period of a few minutes until eventually it would not drive.On investigation, I think the engine was running on 2 cylinders, then 1 and then would not start at all.
    I have checked all the obvious things like a healthy spark at all plugs and there is fuel coming from the injectors. I have checked the timing belt to see make sure the timing marks all line up and they do.
    Any ideas? Could it be the immobiliser (fitted as standard I think)?
    Aug 2006
    Notts
    It certainly could be your immobiliser. I'm not sure how they work but if you have a spark, fuel and it turns over then it seems unlikely. Other things that it could be are air intake system/vacuum system leaks, fuel pressure/delivery rate/fuel pressure regulator, crankshaft position sensor/engine speed sensor, mass air flow meter fault, manifold absolute pressure sensor, coolant temp sensor or ECU fault.
    I guess the best way to diagnose the fault here would be a diagnostic check. Sorry, but its just a guessing game without.
    Jp
    Saltash
    Thanks, I will try checking some of those things.
    I have been looking online and it seems that I can get a ODS lead to plug into the car and a PC. After installing downloaded software it is supposed to allow diagnostics. Is this worth trying? Has anyone had experience of using this?
    Aug 2006
    Notts
    I'm no expert on diagnostics, but i believe DevonUtopia knows his stuff in that area. And he lives in your neck of the woods so may be able to diagnose with his VAG equipment.
    Jp
  5. Exact same problem
    Hi, the same happened to me yesterday, I was driving along great, stopped at a shop and when I restarted it was misfiring and eventually firing on 1 cylinder and now won't start at all. I've checked there's a spark and there's petrol getting to the cylinders so I'm a bit lost. I was going to put it in and get a fault code read done later this week. Have you any solution for yours?
  6. Still trying
    Saltash
    I have just managed to get vag-com diagnostics working (I bought a cable and downloaded software). I first ran the diagnostics and 5 faults were found. My neighbour said that it would be best to clear the existing faults and then re-run diagnostics after trying to re-start the car. This is because some faults could be 'old'. The error that then came up (again) was:
    00533 - Idle speed Regulation
    09-00 Adaption limit surpassed
    I am now in the process of trying to find out what this means. Has anyone got any ideas?
    Nige
    Saltash
    Spoke to a guy at our local garage and he says that the above fault always shows anyway. He said that a common problem is usually with the throttle body. The original 5 error codes refered to a throttle position sensor and manifold pressure sensor problem. I'm still investigating..............
    Any luck with yours arsy?
    Hi Nige,
    Had a volkswagen specialist come around with his scanner today and he found 2 faults but thought these were not causing the problem. He too mentioned the throttle body but he thinks the timing is out and should be checked first. I had a 96 Polo a few years ago with a similar problem and that turned out to be the keyway on the crankshaft became elongated and therefore the timing was moving around, maybe its happened again but suddenly! Going to check it all tomorrow hopefully.
    Saltash
    Thanks arsy
    Please keep me posted
    Nige
    Checked all my timing marks and they're ok .......mmmmmm????
    The reason I suspect the timing is out is that mine is trying to backfire occasionallly when its turning over.....wondering if the ecu has anything to do with it??
  1. sharan just wont start
    By alistair in forum Touran - Sharan - Caravelle
    Last Post: 06-05-2007, 02:08 PM
  2. a6 1.8t wont start
    By loco in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-01-2007, 10:22 PM
  3. a6 1.8T wont start
    Last Post: 06-01-2007, 12:21 AM
  4. Polo GT suddenly wont start
    By biggles0509 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-12-2006, 10:58 AM
  5. MK3 gti 8v wont start.clicking etc
    By Maddoggolfface in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-11-2006, 10:16 PM
