Thread: smelly aircon
Results 1 to 10 of 11
  1. smelly aircon
    hi all
    i have a problem with my aircon when i first put it on it stinks awfull is there any way i could get rid of the smell ie clean it or whatever
    thanx
    hazhammy
  2. Re: smelly aircon
    May 2008
    Not sure how good they are but you can buy those AC cleaning aerosol cans. You turn your aircon on (recirculation mode), set the aerosol off and jump out the car for 5-10 minutes.
    It kills the bacteria etc that lurk in the AC system/vents.
  3. Re: smelly aircon
    Mar 2007
    Lancashire
    The biggest cause of this stink is not replacing the pollen filter and spores build up. Has it been replaced? Also check plenum for any water as this is how I found out mine was. The water had gone stagnent
    Failing that you can run one of those aerosols through the system, they do seem to work as long as the filter is changed regular. I do mine every 12 months max!
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  4. Re: smelly aircon
    thanx
    i dont know when the filters were last changed as ive only had the car a couple of months
    how do i get to the filters to change them and where would i get them from and also the aerosol
    my hubby will probably end up doing it but i would like to have a go myself
    thanx again
    hazhammy
  5. Re: smelly aircon
    Mar 2007
    Lancashire
    Hi
    Try the link below for where and how to change the pollen filter.
    https://www.vwaudiforum.co.uk/forum/s...ghlight=pollen
    I've just changed mine. I bought it from Eurocarparts. They use Hengst products which are good. Only cost £7 ish! Worth doing every year. The one from last year was black.
    I bought a carplan air con aerosol spray. There are many different ones. You put the air con on low temp and full blast. Ensure all vents are open. The aerosol is best places in the back footwell with the front seat (either driver or passanger) pushed forward. Takes about 5 or 10 mins.
    This should help.
    Marco
    Re-map by more-bhp.
  6. Re: smelly aircon
    hi marco
    thanx a lot will give it a go it looks straightforward enough
    hazhammy
  7. Re: smelly aircon
    hi
    job done !!
    filter changed and it doesnt smell anymore
    cost me £14 quid from our local vw audi parts centre
    worth every penny
    so am happy
    hazhammy
  8. Re: smelly aircon
    May 2008
    Is the filter thing on the drivers side on right hand drive cars ?
    I think mine needs changing but being a bit lazy in going out to check.
  9. Re: smelly aircon
    Mar 2007
    Lancashire
    Quote Originally Posted by hazhammy View Post
    hi
    job done !!
    worth every penny
    so am happy
    hazhammy
    Nice one.. well worth £14 to get rid of the stench. Most often it's the cause. Mine looks grim after 12 months, I'd hate to see one from a car on variable service...
    Re-map by more-bhp.
  1. Smelly Cabin
    By the hooded claw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-08-2010, 04:37 PM
  2. Smelly Aircon - Smell like a tramp has been sleeping in my car
    By nutter1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-06-2008, 10:55 AM
  3. smelly air con
    By mac g in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-02-2008, 04:51 PM
  4. smelly air con
    By mac g in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-02-2008, 10:00 PM
  5. Smelly when wet!!!!!!!!!
    By nidges2 in forum Audi A4 - Archive Topics
    Last Post: 08-11-2006, 11:40 PM
