Thread: Semi-automatic climate control/heating question.
  1. Semi-automatic climate control/heating question.
    Apr 2007
    Lancashire
    I have the semi-automatic, ie the system where there's a knob for temp, one for fan speed and one for distrbution.
    My question is this: does that system sense the temperature in the car and adjust output to suit? If so, presumably pre-chilling the incoming air by using the AC just makes it turn up the heat to achieve the set cabin temp? How does the system sense the temperature? Where are the sensors?
    I've noticed that if you sit in the car with ignition on but engine not running you can hear servos inside the dash constantly adjusting something - would this be in response to the inside of the car cooling down or warming up?
  2. Re: Semi-automatic climate control/heating question.
    Sep 2007
    South Manchester
    Correct , not sure where the sensors are though
    VW Passat Estate 2.0 TDI DSG in Silver 2006
  3. Re: Semi-automatic climate control/heating question.
    Air conditioner with manual controls has no sensors which control the temperature,this is done manually with the temp control switch
  4. Re: Semi-automatic climate control/heating question.
    Sep 2007
    South Manchester
    Semi-auto(Climatic written under middle dial) does set the temp based of a sensor.
  5. Re: Semi-automatic climate control/heating question.
    Apr 2007
    Lancashire
    I thought so. Any idea where is the sensor? Is it like a room stat in a house?
  1. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
  2. climate control
    By madmonk in forum Golf MK4 - 1999 - 2004
    Last Post: 15-01-2008, 10:40 AM
  3. Grr Climate Control
    By Cactus Greengo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-11-2007, 07:48 PM
  4. A4 CLIMATE CONTROL
    By Bob R in forum Chat - Completely Off Topic
    Last Post: 06-04-2007, 02:51 PM
  5. A3 climate control question
    By JayH48 in forum Audi A3 - Archive Topics
    Last Post: 10-02-2007, 09:23 PM
