Thread: Central locking and driver's window
  1. Central locking and driver's window
    Jun 2008
    I hope I'm posting in the right place
    I have a 2000 Polo 3dr and for the last month or so the central locking just whiiiiiirrrrrrssssss at me from the boot for about 30 secs and then dies off without locking/unlocking anything. The keys work fine and the alarm also works but no central locking. The strange thing is it sometimes (rarely) works but 99% of the time it doesn't.
    Around the same time (don't think it was exactly the same time) both the driver's and passenger's windows also stopped working, but the passenger window started again and has worked OK since but the driver's doesn't. You can hear it some clicking when you press the button but nothing. You can open the passenger's window using the drivers switch.
    Any help very much appreciated,
    Thnx.
  2. Re: Central locking and driver's window
    Jun 2008
    HI there, funny that i have exactly the same problem with my 2000 polo 1.4 match, it also has no central locking when i turn the key and electric windows do not work except the passenger side window?? its only done 33000 miles which is the most worrying thing!!
    If someone could help us i would be most grateful?
  3. Re: Central locking and driver's window
    Jun 2008
    Snap! My cars done 32,000 miles, although it's been pretty much all town driving. Would be great if someone could help. Maybe I could barter with some IT advice?
  4. Re: Central locking and driver's window
    Jun 2008
    Thought i would update you with what ive found out today, firstly in my case the central locking issue turned out to be a broken paddle in the door lock mechanism, it costs like £5 max from VW and they were kind enough to put the new paddle on for me, so now the central locking works from drivers door, however its really weird because the passenger electric window keeps going down and up when i turn the key in the lock???? so must be some sort of wiring problem i suspect or earth problem?
    The plot thickens though the electric window switches on the drivers door, neither work, and you cannot hear the motor working, on the passenger door the switch does work and the window does work?
    These are the things that people have suggested: 1) new motor, 2) new regulator, 3) try the switch from drivers door in passenger door and vice versa, 4) fuse, 5) relay 6) earth problem in wiring loom
    So tomorrow ill give them a go and update you all!!
  5. Re: Central locking and driver's window
    Jun 2008
    Thanks for the update ppitstop - hope your tests go well. I'm going to have a look myself this weekend at the motors, fuses etc.. so I'll let you know what I find.
  1. Central Locking and Electric Window Fault
    By Joe_Kobrin in forum Touran - Sharan - Caravelle
    Last Post: 09-12-2009, 09:40 PM
  2. Mark 3 VW Golf Central locking/Window problem
    By raines005 in forum Golf MK3 - 1993 - 1999
    Last Post: 12-02-2008, 07:41 PM
  3. Faulty central locking & electric window
    By vwcd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-10-2007, 10:52 PM
  4. 2002 A3 TDI - Electric window and Central locking issue
    By Simmyno8 in forum Audi A3 - Archive Topics
    Last Post: 09-08-2007, 09:07 AM
  5. Central locking / electric window problem
    By sandancer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-05-2007, 06:39 PM
