Thread: Engine Knocking/tapping sound
  1. Engine Knocking/tapping sound
    May 2008
    I have a 2001 A4 2.4. started it this morning and herad a slight knocking/tapping noise from the engine. It increased when i increased the revs. No problem before, no warning lights on, running very smoothly ....apart from the new sound! any ideas what this could be?
  2. Re: Engine Knocking/tapping sound
    where is the noise comming from? the top end or bottom?does the noise happen only under load or all the time?is it a tapping or knocking,the noises are different?
  3. Re: Engine Knocking/tapping sound
    May 2008
    Will get back tonight with a better description on the points you raised
    Thanks for the feedback though!
  4. Re: Engine Knocking/tapping sound
    May 2008
    Ok,
    Had a listen properly last night, and its a slight knocking noise in the top end of the engine. It is coming from the passenger side. Its seems to be only 1 cylinder playing up. The noise is constant.
    Hope that helps
  5. Re: Engine Knocking/tapping sound
    Dec 2007
    You might consider having a check of camshaft/tappets/rockers/springs/movement of in/ex valves
    Check this out:
    https://www.vwaudiforum.co.uk/forum/s...earchid=479923
  6. Re: Engine Knocking/tapping sound
    Dec 2007
    Quote Originally Posted by viodiesel View Post
    Check this out:
    If yes, make sure to check also the thrust discs between the rocker and valve spindles
  1. Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    By keawe in forum Golf MK4 - 1999 - 2004
    Last Post: 09-02-2017, 02:21 PM
  2. Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    By C_jam01 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-06-2008, 10:01 PM
  3. Bora 99 SE2.0 - Tapping/Ticking sound from the engine
    By zimbora in forum Bora - 1998 - 2005
    Last Post: 19-05-2008, 10:53 PM
  4. Knocking sound when driving
    By k9max in forum Golf MK5 - 2004 - 2009
    Last Post: 14-10-2007, 09:40 AM
  5. Slight Tapping, whirring sound
    By Whitie in forum Archive posts
    Last Post: 10-02-2005, 10:30 AM
