Thread: VAG-COM Setup
Results 1 to 10 of 25
  1. VAG-COM Setup
    Dec 2007
    Sheffield
    Can someone clarify a few things for me. Ive recently purchased a HEX-USB-CAN cable off ebay so that I could have a play around with VAG COM before purchasing the whole shebang. It shipped with a cd containing VAG-COM version 60x or something along those lines but ive read on the Ross Tech website you can only use shareware mode on versions prior to 50x releases. Is this the case? Ive installed version 409 but there is no usb option but have managed to get it to register using COM3 however I havent plugged it into the car yet to see if it actually reads the modules.
    Any help would be appreciated im desperate to have a look for any errors as my cars playing up and the warranty is due to run out. Its a MK5 Golf 2.0 FSI.
    Thanks in advance
  2. Re: VAG-COM Setup
    May 2007
    knee deep in clunge
    14 Post(s)
    Cant help with the fleabay lead or the copied cd they have sent you.
    I had a nightmare with my first lead and decided to pay for the full hit and its been great ever since.
    My advise is to buy from registered ross tech distributors ie gendan (uk based) or direct from rosstech.
    Hope you sort it out.
    vag diagnostics, retrofits and general repairs
  3. Re: VAG-COM Setup
    Leicester
    My 3rd party interface installed a usb-to-serial driver and so do I connect using a COM port, not the USB one. Also, definitely try installing it without using the supplied cd (just install the official VAGCOM 409 from Ross-Tech). The cd supplied with my lead caused problems and in the end I wiped all the drivers, reinstalled without the CD and all was fine.
  4. Re: VAG-COM Setup
    Jan 2008
    Angus, Scotland
    If you rlead has been advertised as a Hex-Can-Usb and has shipped with version 604 then it sounds like its one of the copies of the later Ross Tech leads.
    Try installing version 604 of Vag-Com then connecting the lead following the instructions on the Ross Tech website.
    I'm with A8 Tech on this though, the cheap cables are cheap for a reason and a genuine cable is expensive for a reason. you get what you pay for, and buying a genuine cable is quite satisfying. Especially when you know it is going to work each and every time!!
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  5. Re: VAG-COM Setup
    Oct 2005
    Quote Originally Posted by brentos2004 View Post
    Congratulations, you've bought a seemingly illegal item.
    I'd report the seller to ebay and request a refund.
  6. Re: VAG-COM Setup
    May 2007
    knee deep in clunge
    14 Post(s)
    I think there should be a sticky on this subject to guide forum users in the best direction and save them some cash.
  7. Re: VAG-COM Setup
    Oct 2005
    Quote Originally Posted by a8 tech View Post
    Well volunteered my internet friend
    You type it, I'll stick it.
  8. Re: VAG-COM Setup
    May 2007
    knee deep in clunge
    14 Post(s)
  9. Re: VAG-COM Setup
    Dec 2007
    Sheffield
    Thanks for all the replys. I havent tried to rip anyone off here I just wanted to try it out before i purchase the full package from ross tech. I just want to have a play round with it so gona give it another go tonight.
  10. Re: VAG-COM Setup
    Dec 2007
    Sheffield
    Well ive uninstalled everything that came on the cd and just installed version 409.1 which ive managed to get so that it recognises the interface but everytime I try to access a module i get an error " no responce from controller Any ideas what might be causing this? Thanks
  1. HT Lead Setup
    By Strutt in forum Golf MK2 - 1984 - 1992
    Last Post: 31-05-2008, 10:36 PM
  2. Question Any recommendations - steering setup??
    By Dudey Head in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 13-05-2008, 10:13 AM
  3. An interesting setup...
    By Ben in forum Chat - Anything with wheels
    Last Post: 03-05-2008, 10:44 AM
  4. A4 wheel setup
    By D-L@t A4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-02-2008, 06:45 PM
  5. Getting VAGCOM setup
    By Scottyjohn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-10-2007, 03:03 PM
